Question about Toshiba Satellite A135-S2356 Notebook
Can i buy and install my own memory upgrade? if so what are size and compatibility issues to avoid? thanks
  • Henry W. Newell Jul 16, 2010
    thanks. learned a lot in the faq's
  • 699 Answers
Toshiba Satellite A135-S2356 has a maximum of 2GB which can be installed in the maximum 2 memory Slots in the memory compartment: 2 X 1GB PC2-4200 DDR2 SODIMM (200 pins) memory stick.
Note that in general, especially for older laptops, that you should not mix different size/brand of memory stick as the unit may even fail to boot or can behave erractically (reboots or system freezes).
Hope it helps.
Posted on Jul 16, 2010
  • 206 Answers
Yes you can and the compatibility issues are that they have to be compatible with your motherboards size!
Posted on Jul 14, 2010
    President:
  • 1,768 Answers
1. You will have to know your system requirements for the upgrade for memory. Contact your manufacturer and check their web site for upgrade information for your particular PC unit then shop for the best memory upgrade for your unit.
Knowing where to input the memory sticks will be the next step and inserting them in the memory slots properly.
Consult your user manual for this procedure.
I hope this helps. have a great day!
What is the maximum upgrade ram or memory AND compatible for NEC VY22XRFZJEFL? I WANT TO BUY MORE MEMORY TO MAKE MY RAM 3GB or higher to make it fast
Several memory vendors will help you find the answer. I like http://www.crucial.com/store/drammemory.aspx It walks you thru finding how much and what kind of memory you have and what you can install.
Oct 05, 2012 | NEC Versa Computers & Internet
Memory
One of the easiest methods of determining what memory your computer has and what upgrades you can install is to go to the Crucial Memory web site and use their Crucial System Scanner Tool, this will try to detect exactly what make and model your system is, and from this advise both what the currently installed memory is, and show compatible memory upgrades for your system.
Jan 05, 2012 | Gateway E4300 (E43001008508) PC Desktop
I have installed windows 7 on p5vd-mx and it is not working fine what is the solution
This board may not support Windows 7 unless you install a video board with 128 MB or more of graphics memory. The onboard video appears to be only 64 MB. The main memory should be at 4GB even though Windows 7 will operate at a minimum of 1 GB(very slowly). I would first run the Microsoft Windows 7 Advisory software to see any compatibility issues. If it was my decision, I would get a new ASUS motherboard certified for Windows 7 with DDR3 memory, a 1GB graphics card, and a 1TB Hard Drive. Upgrading to Windows 7 requires a computer upgrade in most cases.
Aug 17, 2011 | ASUS P5VDC-MX Motherboard
Samsung n145p memory upgrade how to install and what to do
Here's where you can buy (i've you didnt already)
http://www.crucial.com/upgrade/compatible-memory-for/Samsung/N145P-JP01/list.html
How to install the new RAM:
Jun 13, 2011 | Samsung Computers & Internet
Getting notice that I'm low on virtual memory.
To get system info:
Start > Run > MSINFO32
then hit enter..
Although i don't remember if it works on MS Windows 2000.
It should list the RAM and Page File (Also called virtual memory) in last 2 lines under system summary...
Aug 09, 2009 | Microsoft Windows 2000 Professional Full...
Memory upgrade
We have the memory you need. Memory-Up is committed to provide the best memory and excellent services for all of our customers. We know that sometimes it is a bit confusing to buy the correct type, speed, and capacity of memory for your system. Therefore we hope that these tips below would help you for buying the new memory.
Memory Upgrade Tips
What is Compatibility and Memory Density Issue?
Memory module can be composed using different type of memory chips and therefore created different type of density for the module. For instance, a 512MB PC2700 DDR SODIMM memory can be composed using eight 32x16(High Density 512Mb technology) memory chips or sixteen 32x8(Low Density 256Mb technology) memory chips. As the laptops are equipped with different memory chipsets, some older laptop (chipset) would have compatibility issue working with the modules that is built with the newer 512Mb technology. Using the Not-Compatible memory will result the laptop to either not boot or only recognizing half of the memory modules. Thus that is not the correct memory for your system. Our Memory Finder and Memory Scanner will help to eliminate those problems and find the correct memory for you. We guaranteed the memory to work or your money back.
How much memory do I need?
Here are some general descriptions for different type of users and the amount of memory they would need for their systems.
Normal User: The system is mainly used for checking e-mails, processing word/excel file, and web surfing. Suggestion: 512MB to 1GB of system memory.
Power User: The system is mainly used for playing computer games, editing photos/videos, running database queries, or multi-tasking environment. (Surfing web/Processing Word/Excel File/Listening to Music). Suggestion: 1GB to 2GB of system memory.
Super User: The system is mainly used for running large number of database queries, professional editing of photos/videos, heavy multi-tasking environment. Usually a server or a workstation would be considered as Super User due to the multiple accesses from users. Suggestion: 2GB and above of system memory.
How much memory and memory slot do I have with my system?
You can download our Memory-Scanner to find out the the amount of memory that you have and the memory slots that are available for upgrade.
How many memory module should I buy?
It is recommended to purchase one module with bigger capacity than two modules with smaller capacity. For instance, if you can buy either one 1GB memory module or two 512MB memory modules for your system, it is recommended to get one 1GB and leave the other memory slot empty for future upgrade if necessary.
Note: For systems that supports dual channel memory mode, although memory modules need to be installed in pairs to enable Dual Channel Memory Mode, we still recommended users to purchase one bigger module than two smaller modules since Dual Channel Memory Mode has only a minimal improvement in the actual system performance.
What if I want to mix different memory together?
Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 256MB and one 1GB of memory for the total of 1.25GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules. We recommend users to use our Memory Finder or Memory Scanner to find the correct memory for your system.
i thnk that will helpfull for u
Oct 18, 2008 | HP Pavilion ZE5730 Notebook
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Zlatko
Your laptop can have up to 1 GB of memory. You should have two slots and you can install 512 MB per slot. Your laptop is using 200 Pin DDR PC2100 266 MHz CL 2.5 SODIMM. You can also install PC3200, but your laptop will clock it down to 266 MHz.
Regards,
Feb 27, 2008 | ASUS A2H (A2HOB) Barebone
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Toshiba Satellite A135-S2356 Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
