PANASONIC PT-61DX80A 61 IN. REAR PROJECTION (1999) LOWER LEFT CORNER STARTED GETTING DISCOLORED- PURPLE. NOW WHEN YOU TURN IT ON, YOU CAN HEAR IT START TO WARM UP, BEFORE THE PICTURE APREARS, IT TURNS ITSELF OFF.----HELP
  • Mary kat Jan 28, 2009
    Panasonic PT-61DX80A left bottom corner is discolored-purple and has double images and wavy lines in the left bottom corner only
  • 65 Answers
SOURCE: Convergence Problem
i think that it needs stk packs
Posted on Dec 09, 2006
SOURCE: Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jun 03, 2008
  • 87 Answers
SOURCE: Spots on Hitachi 53SBX01BA
green tube has problem maybe bugs if your lucky and lens has to be removed. If your a novice at tv repair call a service center
Posted on Apr 29, 2009
ArnelM
  • 184 Answers
SOURCE: some green spot, purple and red are showing on the tv screen
Try updating the software first :)
Posted on May 27, 2009
vernonallen5
  • 134 Answers
SOURCE: BLUE PATCH SHOWING UP IN
This is called the blue spot defect.. NOT trying to be smart but it is known by Sony. It requires replacing the light engine. contact Sony customer relations. Your set is part of a fix . service bulletin e27964821 It expires march 2011. The repair will be free of charge to you once Sony issues your local service center a repair action work sheet.
Please leave feedback
Posted on Feb 21, 2011
Panasonic PT-43lc14 blue dots lower left corner of screen
A problem in the optical light engine this set uses to project the picture on the screen---if right cost of repair will exceed value of set or cost of a new set.
Oct 29, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Color wash at upper right corner of screen and lower left corner, color bleed. Resembles the colors of a florescent yellow or purple highlighter.
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 27, 2009 | Panasonic PT-61HX40 61" Rear Projection...
Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My colors on the screen were way off
I would suspect the convergence IC's are bad, look for STK392-110; replace.
Feb 20, 2009 | Panasonic PT-61G54 61" Rear Projection...
Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Jan 14, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Spots on picture
I had the same problem. Panasonic is kind of a pain about the whole thing. You have to find out who your local Panasonic repair place is, tell them there is a service bulletin and they will get on it. You must be diligent! Do not take no for an answer! If it comes down to it, and the repair shop won't do it for you, then call Panasonic and endure a loooooong wait time. Trust me though...this is the issue. Once the eeprom gets fixed/updated/whatever, the picture looks amazing! Good luck.
Aug 16, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Television Set Popped, Now Left with a Cicking Sound
Your problem more than likely lies in your lamp. The whirring noise you hear is the ballast trying to fire up the bad lamp. The lamp part # for your set is TY-LA1000 and can be purchased online at vance baldwin. This is something you can easily replace yourself and your owners manual will give you instructions. Hope this helps
Mar 31, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
