Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
How do I get the string spool off? - Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
    Sergeant:
  • 200 Answers
If it is like mine push down really hard on the bottom red button and turn.
Posted on Jul 19, 2010
Black & decker LST201 direction loading the string weed eater
when you are holding the spool on which you wind the string wind the string on in a anticlockwise direction
if it uses 2 strings ( one out of each side of the spool
wind in both strings together in the anticlockwise direction
that way , when you put the spool in the head and go to use it , the string is wound the right way to feed out and not get tangled
Sep 10, 2016 | Sewing Machines
Possible Line-Feed Problem
The notches are there to hold the line in place while you place the spool back on the trimmer. If you look at the spool, you will find, on one end or the other, an arrow showing direction to wind the string. Follow the direction and when you get the spool full, place it into the notch. Leave about 6" sticking out and cut it off. If you have a two string spool, just wind the other string as you have done the first. When you have both spools full and the ends in the notches, place the spool on the trimmer. As you start the spool on, place the string (or strings) in the respective holes. As you seat the spool pull the string that is the farthest in until it comes out of the notch. Do the same with the other string. Seat the spool and try your handiwork. Good luck...Lee
May 28, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
How do I load string in a P2500 string trimmer??
Remove spool by firmly pulling on tap button. Cut two pieces of line (0.080) about 12 feet. Insert the two ends of the line into the small holes inside the spool. Wind the lines evenly and tightly on the spool. Wind the string in the direction of the arrows on the spool. Push the lines into the notches on the spool leaving three or five inches hanging there. Insert the two ends in the two holes in the hub. Align the notches on the spool with the holes in the hub and push it in until it snaps into place. Pull on the lines to release them from the notches.
May 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
No directions on how to re-string the spool on my TB-720
On the bump mechanism, line up the two arrows, then unscrew the bump, this will release the spool, then you wind the two strings in the opposite directions, the arrow on the spool will tell you the direction to wind the string, replace spool, spring, bump feed, and you are good to go. I hope this has helped you.
Jul 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
How to change the string
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 26, 2009 | Garden
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
24 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Gene Tuck
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
