Question about Ricoh FAX1900L Plain Paper Laser
HOW DO I CLEAR COPY..
I HAVE TRIED EVERYTHING I KNOW, BUT IT WILL NOT CLEAR. I CAN SEND FAXES, I CANNOT RECEIVE.
Cannot send Fax Memory Full
The most easier way is to disconne, the power suplly cord.Wait few seconds and connect again.
Jun 22, 2010 | Canon FAX-L100 Plain Paper Laser Fax
I CANNOT GET OR SEND FAXES ANYMORE. IVE TRIED
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 25, 2010 | Canon MX310 Office All-In-One Printer
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
We have a Sharp UX-B700. Unable to send clear faxes.
The scanner that scans the paper is likely dirty. Pull the cover with all the buttons toward you, and clean the glass that the paper slides by, preferably with a soft cotton cloth and some rubbing alcohol. Try to make a copy to see if the quality is improved
May 06, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP C7280 All in one wont send faxes
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Feb 02, 2009 | Office Equipment & Supplies
Cannot RECEIVE faxes.
I have a HP C6100 Series and can send faxes but cannot receive
Jan 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot receive faxes
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
U will be able to send and recieve faxes.....
Thanku.............
Jan 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can not send faxes, but can receive them
this is for the uf 7000 you need to do an all job clear on the machine to try and fix your problem, sounds like a memory lockup
Oct 02, 2007 | Panasonic PanaFax UF-7000 All-In-One Laser...
I cannot send nor receive faxes.
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
Apr 29, 2007 | Brother MFC-5840CN All-In-One InkJet...
Ricoh FAX1900L Plain Paper Laser Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
