Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
I am having a canon pc1192 digital camera which got wet in rain at night on 11/06/10.As soon as i reached home i opened its batteries and its data card..and kept it like that.next morning i kept it in sunbut as it is raining herethe sunlight is not thereits cloudy.what To do nowits still not working.
t00nz
  • 4738 Answers
SOURCE: troubleshooting problems
Take a picture with the camera and download it. If the pictures also shows up white then this probably is a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Nov 23, 2007
SOURCE: Canon UXUS i pc 1060 pictures bleached white
I've got the same problem.
Happened just two months ago. I was outside taking pictures by a campfire, so I wonder if the smoke had something to do with it.
Movie mode is fine, but regular photos are either all white or with strange horizontal lines, not clear at all.
I'm going to open it up and reseat all the connections.
Anything else to try?
Anyone else have this problem or know what to do?
Posted on Nov 13, 2008
  • 53 Answers
SOURCE: cloudy lcd monitor
u change the settings to auto which in menu u can change
ta wil help u take photos in all type of climate
Posted on Mar 07, 2009
  • 8 Answers
SOURCE: my camera got wet in the rain and now it wont work
Take out the batteries. Take a hair dryer and try blowing the hot air along all sides of the camera. If your camera has a plastic body, make sure not to stay in one area to avoid discoloring the plastic.
Blow the air in for a good 5 minutes. This trick has worked a few times on cameras and cell phones.
If it still doesn't work, more than likely you have shorted out the circuit and it will need to be disassembled.
Posted on Jul 25, 2009
t00nz
  • 4738 Answers
SOURCE: its shutter is not opening
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Dec 20, 2009
Camera has died after getting cold and wet. How can I get it to restart?
Hi A Strootman,
How did it become wet? Was it rain, snow, or salt water. If salt water you may be in for a big repair bill. Most digital cameras do not do well in rain, nor in very high humid locations as well. You may need to have a CLS performed by Canon.
Jan 31, 2016 | Canon PowerShot ELPH 530 HS Digital Camera...
Stupidly but accidentally left my Canon PowerShot SD800IS outside on table and it rained!!! I can't see anything through the screen! Stick seems OK. Battery is functioning. What can be done. Thanks.
Well you can try not to turn it on and let it dry out in a DRY room
But if you turn it on after it was still wet or it was not fully dried ...Then
you have to bring it to a camera repair shop I would call around but
make sure that you do not tell them it was wet because it they may tell you that
there is more problems then just the LCD screen.... So if the board is wet and
there was power turn on there will be clear signs of the residue left from the rain...
You can also call Canon to see if they no of any Camera Shops in your area that will Repair
it or Maybe give you a trade in credit towards a used or new camera,
Thank You
Jayson
Sep 15, 2008 | Canon Cameras
What is error code E23?
Traditionally, the E23 error code in Canon Powershot models is the CF/SD card memory full error. Do you get the same error message when using another card or when there is no card in the camera?
If you've tried a different memory card and made sure it's inserted properly and still get the the error then the camera is water damaged. Canon repair manuals indicate the E23 error is generated from the "PCB board" (main camera electronics) so the only option would most likely be a board replacement.
HOWEVER - I can make this suggestion. I had a Canon DSLR get submerged underwater in a "moose vs canoe" incident some time back. I read to remove the battery and memory card (leave the doors open), wrap the camera in a clean, paper bag and completely cover it in a bowl of plain, dry, uncooked white rice to absorb moisture that may be trapped in the camera. It's a last ditch effort and may already be too late, depending on how wet your camera got and how soon you can do this. You'll need to leave it in the uncovered bowl of rice for at least a week and keep the bowl in a dry area. This worked for me but my camera was completely submerged for less than 10 seconds. Good luck!
Aug 09, 2014 | Canon PowerShot SX170 IS 16 Megapixel...
Canon PowerShot SX30, error e40
Can anyone help on this issue? The same issue I am also facing the same issue. on Saturday, my camera got drenched in rain. Is it something to do with this getting wet in rain?
Jan 30, 2012 | Canon PowerShot SX30 IS Digital Camera
My Canon digital Rebel got wet in a rain storm yesterday. I took out the battery and let it dry out, but now it's not working. Any suggestions?
If you didn't take off the lens the interior shouldn't have gotten too wet. The best thing to do is take it asap to a camera repair center where the top cover and be removed and dried out. Otherwise send it to Canon and if they can't fix it you will most likely qualify for the Canon Customer Loyalty Program. A refurb XS will cost about $350 with a trade.
Aug 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Its shutter is not opening
Dec 18, 2009 | Canon Cameras
Camera (DMC-FZ10) got wet in a rain storm. Now
I suspect that water has damaged the electronics board in the camera. Unfortunately this is not a waterproof camera. Water will corrode the electronic components and eventually ruin the whole camera,
My suggestion is to claim it on insurance as they wilol repair or replace it on Home insurance. No one puts a camera in water intentionally unless its an underwater camea, so its considered an accident
Please rate our help to keep the Free service online ++++
Thank you for using FIXYA
Sep 01, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
Camera got wet and does not turn on now. Please help!
How "wet" did it get? Totally submerged, or just a little rain? About the only thing you as a consumer can do would be to remove the batteries and the memory card and squirt a good brand of electrical contact cleaner (NOT, I REPEAT, NOT ANYTHING SUCH AS WD40 OR ANY OTHER TYPE CLEANER). The good stuff is available at Radio Shack for about $12.00 a can. Use sparingly. This should displace all the moisture and cause rapid drying of the innards of the camera. Let dry completely for a day or so in a warm, NOT hot, place. Replace the batteries and try turning it on. Some components, no matter how small the electrical current will fry no matter what. Modern digital cameras are supposed to be able to withstand a certain amount of moisture. Other option would be to take it to a high end camera store and see how much they would charge to open it up. If I have helped, please rate my answer accordingly. Good luck.
Jul 05, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
853 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
