Question about Car Audio & Video
Alpine MRV-F345 VLT ERROR
Hi when i turn on my Alpine MRV-F345 it displays VLT and cuts off only started doing this yesterday and my system was properly set up untill this error can you help me resolve this issue.thankyou
    Genius:
  • 1,139 Answers
This is an indication of a voltage error, I have seen this when the voltage regulator or the car battery is begining to have a problem supplying enough current to the amplifier. Check the voltage levels with the amp turned off and then turn on the amplifier, if the voltage drops this means that there is poor voltage regulation and this may mean that you will have to replace the car's voltage regulator.
I hope this helps,
Thank you,
Shuttle83
Posted on Apr 22, 2008
Alpine mrv-f345 cuts off when...
Yes sounds like your not getting enuff power from the battery could be your alternator you should have it tested. Also have you try'd a capacitor? I put one in my car and it stopped cutting out...
Feb 05, 2010 | Alpine MRV-F345 Car Audio Amplifier
Alpine Amplifier Cuts in and out on Passenger side while driving
Make sure wirings are not pinched and try replacing the fuse as well.
May 01, 2008 | Alpine MRV-F345 Car Audio Amplifier
My amp turns on but the sound goes in an out
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Alpine MRV-F345 Car Audio Amplifier
Same thing
Doubtful sir, your problem mostly enlies in the fact that the Alpine amplifiers are stable at 2, 4, and 8 ohm loads more than likely you have it wired at something under a 2 ohm load. This makes your amplifier do many things including not work properly. A properly wired amplifier should stay cool, and never shut down. Go to www.the12volt.com and veiw their subwoofer wiring diagram section. choose your subwoofer impedence and how many as well as how many voice coils. enter that into the drop down menus and you will be presented with all your wiring options then wire accordingly
Jun 09, 2009 | Alpine MRV-F345 Car Audio Amplifier
Fan not working
iT SOUNDS LIKE THE FAN IS NOT WORKING RIGHT, SO CHECK OTHERWISE IT WILL COOK YOUR AMP
May 16, 2009 | Alpine MRV-F345 Car Audio Amplifier
Mrv F345 power cut out and now the screen flashes blue
disconnect all of the speaker wires at the amp and turn your system on -if the amp stays on then you likely have a roasted coil in one of your speakers somewhere and causing a short which is shutting your amp down into protection mode-if the amp wont stay on with nothing connected to it then you have probably roasted something inside the amp and uhhh good luck bro
May 09, 2009 | Alpine MRV-F345 Car Audio Amplifier
Wiring door speakers
Just make sure that the speakers are the correct impedance and properly rated. If not, the amp can be damaged.
Jerry G.
Apr 27, 2008 | Alpine MRV-F345 Car Audio Amplifier
Displays "CUR"
You probably have too low of an impedance load on ot (too many speakers or wrong kind). It has to have a minimum of 2 ohms on each channel, or 4 ohms if bridged (that means don't put 2 subs on the bridge!!).
Sep 22, 2007 | Alpine MRV-F345 Car Audio Amplifier
Error code on alpine mrd 500
It's a current overflow in the system. You can also get this message if the voltage is too low. Also it can mean a short in the speaker cable. E3 Error is a general error "eccessive current overflow". Check the fuses, I believe there are 4 in this unit but not sure. Check your crossovers. I hope this helps you out. Is this a new hookup or did you buy anything new or change anything?
Jul 06, 2007 | Alpine MRV-F345 Car Audio Amplifier
Car Audio & Video Logo
360 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
