Refrigerators Logo
A
Anonymous Posted on Jul 08, 2010
Refrigerator section dripping from top.the refrigerator is very full and the freezer also but no dripping from freezer . i wonder if there is to much food in it. Also I see some ice build up where the air comes out in the back?
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Jul 14, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1542817
Points
14368
Its much too full.........
There is a drip coming into the refrigerator from the ceiling , but the freezer is not frosted
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Water is dripping from the top of thr refrigerator section, towards the back, possibly from the freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
The freezer section is defrosting continuously and water is dripping down through refrigerator and on the floor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Water is dripping from freezer into refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Water dripping into the refrigerator
Sounds very common. Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator. I am not finished so plaes don't rate me until I complete. Sea Breeze
My refrigerator is not cold enough.
I had this repaired by replacing the motor-fan in the refrigertor behind the air deflector which sends the air from the freezer to frig. hope this helps. The motor was not working.
5helpful
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
4helpful
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
