Question about Maytag Atlantis MAV6000 Top Load Washer
Off balance when it spins it walks. I have set the feet and it is level. seems the drum is off center maybe....any suggestions? I have to basically sit on it to keep it from going totally bezerk.
  • maytag prob Apr 20, 2008
    so given that that is the problem is it worth fixing? how much does a fix like that run?
    PS your fast response is awesome. Thanx!
    Champion:
  • 207 Answers
Unless bearing is heavily demaged than it must be that shock absorbers are dead and need to be replaced. That is a typical malfunction and something that experienced DIY guy can replace.
Posted on Apr 20, 2008
  • Ljubomir Vucinic
    Ljubomir Vucinic Apr 20, 2008
    Perhaps even both bearing and shock absorbers need to be replaced. It's easy to tell for any experienced DIY without disassembling the machine.
  • Ljubomir Vucinic
    Don't you worry at all about how long the machine will run after those parts are replaced. When it matters solely those replaced parts it will take years before they need to be replaced again. It is normal that those parts quack. Those parts can be replaced not just once but several times in a lifetime of the machine. If the rest of machine is in good condition there is no question about if replacement of shock absorbers and bearing will pay up or not.
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Whirpool top loader off balance in spin cycle
Your machine is probably not standing perfectly level. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Apr 03, 2011 | Whirlpool Washing Machines
Spin cycle loud maybe off balance
Apr 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
The Maytag PAV 2300 does not spin right if the load is slightly off balance. It bangs on the side and ordinarily lists to the right. On inspection, the washer is on level.
The list to the right should be resolved. Use a level and level the case left and right, and front to back. The final step is to tilt the machine fully on to the front legs, releasing the self leveling rear legs, and set the machine back down. It should be stable on the 4 feet.
usually this will center the drum and it is more forgiving on balance issues, most of which are common. Be sure to use MORE than enough water for more even loads.
Feb 05, 2011 | Maytag PAV2300 Top Load Washer
During the lest spin cycle ,the drum spins like its out of balance, with bad knock , viberation. even after making sure the load is balanced in the drum. even without a load or water, (empty) it still...
The machine sounds as if it might be unsteady. If it only happens on the spin it is probably slight. Try levelling it at the feet, using a spirit level helps enormously to get it level.
Dec 09, 2010 | Washing Machines
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
UE Error wm1814cw
Its probably the drum itself. try rocking the drum or spin by hand some and see if the error clears. If so you probably have a worn out drum support/balancers
Aug 27, 2009 | LG WM1814CW Front Load Washer
Seems to be balanced but it walks all over the floor when it is in spin cycle
take a level and level the machine. front to back, side to side, and corner to corner. If your floor is slippery put small peices of leather under the four feet.
Aug 09, 2009 | Frigidaire Washing Machines
Washer constantly goes out of balance
1 option is to wind the back feet out so the washer drum will sit more to the front so as it less likly to hit the OOB switch, other thing is that the OOB switch might have corrosion on the inside of it and in this case if it gets moisture inside it during a wash it is more likely to go OOB, so try replacing it this should fix issue, if not replace Motor Control Unit. :)
Feb 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag top load washer
This solution applys to many Maytag washing machines. Perhaps not all.
Maytags have three damper pads in the bottom of the machine that must be lubricated from time to time. If they are not, they can be ripped off. They are glued to the bottom of the machine, the drum rests on top of them. When they become dry or lost, the machine shakes violently and no amount
of leveling or load balancing will fix it. Replace and/or lubricate the pads and magically it works again.
This is not a difficult repair for those that have modest mechanical skills and a few basic tools.
replacement pads and lube come in an inexpensive kit.n
I will create a web page with instructions if there is interest.
Jan 28, 2008 | Maytag Neptune Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
249 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
