Question about Toshiba Satellite 2455-S305 Notebook
I have a problem with my TOSHIBA DVD ROM SD R6012, dont read enything DVD, only CD
  • thecrazynic Jul 15, 2010
    This is a good solution, but i am not dvd rom drivers... and there isnt drivers, toshiba dvd rom sd r6012, in the toshiba download.
    President:
  • 1,768 Answers
1. you many need to remove and reinstall the device if removable. Then re-install the ddriver set.\More than likely the laser "read" is defective. This is usually a needed replacement unit.
2.Contact Toshiba technical support. There also may be a loose cable which in any case will require a tech to disassemble the PC unit and repair it.
I hope this helps. Have a great day!
Posted on Jul 14, 2010
I have a question...can i write cd`s with toshiba dvd-rom drive sd-c2612
No it needs to be a Read write one. Check it out with Toshiba help line.
Thanks
Dec 30, 2010 | Toshiba DVD-ROM drive - SD-C2612-D DVD...
My cd/dvd-rom is not working or even showing up under device mgr on my pavilion ze2000 please help
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Apr 03, 2010 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Toshiba SD R2312 CD-RW/DVD-ROM
I have the same problem like you.one of the expert shared to me that my burner has faulted. I thing your problem is worse than mine cause I can still read cd rom vcd/ DVD files and movies. Just finfd new one that will give you quality output.
Aug 27, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Toshiba DVD-ROM SD 6012
Im sorry to tell you this my friend.. it seems I catch you a bad time but I suggest that you need to replace it with a new drive since CD/DVD writers has its life span limit.. Be careful in doing burn CD's especially if its in long hours since it tend to damage the lens of your drive because of too much heat that was prolonged in a long run.. If your'e using it as DVD ROM at the same time, I suggest that you must have another drive to minimize damage to your drives..
Feb 05, 2008 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Toshiba DVD ROM SD R6012 can not burn DVD in my Satellite A25-S307
might be a cd rw /dvd rom player only not burner ? u can buy extrenal dvd rw 79 bucks at any store
Jan 23, 2008 | Toshiba Satellite A25-S307 Notebook
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Toshiba SD C2512 reading DVD but not Cd
solution for CD-rom problem: turn CW the second little potentiometer with a tiny screwdriver, just a little and try to read a CD, if it doesnt work then try turn the potentiometer again. the same solution for DVD-rom but with the first potentiometer.
Nov 12, 2007 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Toshiba SD R2132 CD-RW/DVD ROM
Your CD "Burn" laser or "Quadrant Detector" has "Faulted" a very common occurrence for these "Combo" drives,...So..I'm sorry but ya gonna haveta get another... as these ya can't fix. :(
Sep 18, 2007 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Toshiba Satellite 2455-S305 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
