Question about AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor
I need a rebilding kit for a.osmith motor mod c48k2pa105 1 hp 115/230
  • John Prohaska
    John Prohaska Jul 14, 2010
    There is no such thing...what parts are you interested in getting?
    Novelist:
  • 116 Answers
There are no rebuilding kits per say. Rebuilding a motor entails stripping it down and replacing what's bad. whole inside should be cleaned of debris, dust, rust etc. Almost always bearing are replaced. Armature, rotor and stator are cleaned, motor windings tested, start/run caps tested and replaced as necessary. Thermal overload, contactor, relay, centrifugal switch, etc, tested and replaced if needed. You can order bearings and capacitors from several places online, other parts can be harder to find. I local pump repair shop may sell you parts as well.
Posted on Sep 21, 2010
How to fix 1982 xs 650 yamaha starter?
it could be your button i know this bike very well
does not matter if it is the xs 1 or the xs2 the same set up applies
there are a few components you need to test first
starter button
starter solenoid
wiring
main fuse
i will also tell you some major mods i did to one
when i was dragging the xs650 at super twins
which included a rebore to a 1056cc and having 7 gears
and a turbo
to eliminate the button
with the battery still connected
get a spanner or a screwdriver and not doing it to long
arc out the two polls on your starter solenoid
if you do not know what that looks like follow the main red wire
that goes from your battery
the first stopping point will be the starter solenoid
one poll clamps the main wire from the battery
second poll clamps the main wire to your starter motor
arc out the two polls with a spanner or a screwdriver
to test the motor
if your motor turns the engine then it is not your starter
the problem lies in either your
starter solenoid, (this is a sealed unit replace unit with a new one)
the wiring, (test main wire from your ignition to your switch
also test wire from your switch to your starter solenoid also clean all your wiring connectors)
your starter button, (strip and clean)
main fuse, (replace with a new one)
if the motor does not turn
then you will need to remove the starter motor
before you take the starter motor apart
test it with a multimeter
set on omes test each wire on the body of the starter motor starter
to check if the windings inside are earthing out on the body
if there is a reading on the multi meter
then your windings are earthing out
if there are no reading it may just need a clean up and new brushes fitted
and reassemble your ride
TRIED AND TESTED ENGINE MODS
if you play or really want to play there are a few major mods you can do that have been tried and tested
REBORE TO 1056CC GRASSTRACK MODS
parts needed
slab billet alloy 13in x 8in x 1.5in (for stroker kit)
or a pre brought stroker kit from halco tuning or wisco
get 2 mercedes benz 2.3 pistons ( for rebore)
2 barrel liners
find a good engineer and rebore your barrels and fit new sleeves
fitted with your 2.3 pistons
by fitting the stroker kit you will lose the standard top engine mount
or have more made as you by now should know a good engineer
EXTRA GEARS
remove kick starter reduction gears
find a good engineer and have 2 more gears made up
and fit
TURBO FITTING
tried and tested turbo fitting
a mk 1 land rover turbo is small
and can be fitted under the carburettors
with a heat shield fitted between the carbs and the turbo
these are all mods i have done to the xs650
i built and raced i got to 180 mph over the 1/4 mile strip
with a xs650 hardtail chop that looked like a standard engine
have fun
Jun 22, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Trigger repair on crosman nitro air rifle
http://www.gatewaytoairguns.org/GTA/ is good place to start, you will get all the free advice and info you need.
Largest air gun forum, international. Free to join, all you have to do is luv air guns.
Youtube has some good mods but...
This is the best! It's like the Rolls Royce of triggers!
http://charliedatuna.com/GRT-III%20Trigger%20New.htm
Feb 03, 2013 | Crosman Nitro Venom Air Rifle 0.177
I have a 1/2 Hp a.osmith **** for a well, it pumps up to pressure, turns off then continuosly pushes the water pressure out of the system within a minute or two then it turns on again? Check valve?
You didn't say which way the water was going. I am assuming back into the cistern and it that is so, yes, the check valve has failed or gotten full of trash. Change or clean it, might even be able to replace the flapper seal.
Oct 04, 2012 | AO Smith A.o. Smith T46056 7 1/2 Hp 3...
I have a Suzuki HP-97 electronic piano and the keys stick. What should I do to get them unstuck?
I called VMI Electronics and they sold me a repair kit called Key Mod, you can reach the company at: (619)244-0006 you can also orderer the repair kti through ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Jan 08, 2011 | Suzuki Music
How to rebild carb and replace
You'll need to buy a rebuild kit for your specific model. The instructions with different kits vary from almost nothing to not much more than basic instructions. If you want complete step by step instructions, then you should buy a Haynes or Chiltons repair manual for your specific vehicle. Rebuilding a carb is really not that hard and with a good repair manual, you'll be handy at it right away.
Some public librarys have a section with repair manuals for many of the more common vehicles.
Dec 30, 2010 | Ford F-100 Cars & Trucks
When I pull the cord to crank it does not engage the motor. It recoils but it just free spins without engaging.
there should be four or five small bolts that hold the pull start unit on. remove this and look in side. you most probely will need to get a rebild kit. these are avalibal from most lownmower shopes.
Mar 13, 2010 | Garden
How much are piston rods or a rebild kit
you may want to get an *** import motor as it will be much cheaper than a rebuild,especially if youre not keeping the car for 7 or 8 years,rebuild will cost $1,550 plus a whole decent engine will cost $500 or so
Sep 21, 2009 | Toyota Paseo Cars & Trucks
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor Logo
848 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
