Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
ROBINAIR 34788 NO MANUAL REFILL
THE MACHINE WILL NOT DO A MANUAL REFILL TELLS US SOURCE TANK EMPTY.
    President:
  • 180 Answers
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
Posted on Jul 14, 2010
  • 1 more comment
  • chris21k Sep 29, 2010
    i have the same problem with my robinair ac790pro. i'm not sure where the tank fill adapter to source tank is tho?
  • Hasan Khan Amran
    Hasan Khan Amran Oct 01, 2010
  • stosh1079 Jun 09, 2011
    i have similar problem my screen say source tank empty then we fill the tank to 12lbs then next minute it will say it only has 2 lbs fill source tank
My 34788 will not transfer from souce tank & will not recover
Posted on Aug 17, 2012
Robinair 34788 keeps overcharging the isv how do i fix this issue or how do i find out whats wrong
Robinair 34788 Set Up Operation Part #1 - YouTube
? 6:05
www.youtube.com/watch?v=XW8o5tahLpE
Aug 30, 2013 - Uploaded by OTC TOOLS This video takes the viewer through the entire Set Up and Operation of the 34788. The Cool-Tech 34788 ...
Aug 26, 2015 | Robinair Measuring Tools & Sensors
Robinnair 34788
It's sound like problem from the relay board not from scale. Replace new relay board with old scale assy.
Thanks
Jun 27, 2014 | Robinair Cool Tech 34700Z Recovery,...
WHERE IS THE FILL SOLENOID
If you have model : 34788 or 34788-I please see the attached picture to identify tank fill solenoid. 37b7cee0-d212-4295-9e21-ab8d41e52789.jpg
Jun 25, 2014 | Robinair Cool Tech 34700Z Recovery,...
How to replace tank fill solenoid on robinair 34788
No, you cant remove tank fill solenoid until close low (Blue) and high (Red) side valve on ISV tank (Internal storage vessel). see attached picture to identify Tank fill solenoid. 39b3bb9f-14fe-4040-a186-3a3a23d2848e.jpg
Jun 18, 2014 | Robinair Cool Tech 34700Z Recovery,...
Won't refill from source tank. Trys to, solenoid buzzes, then quits trying.
If it is a 34700-2k or 34700z it could be the check valve that is between the solenoid and the block if it is a 34788 the check valve is brass cap on the side closest to the solenoid. you should be able to blow through the check valves one way they only take 3 psi to open if it will not open it will need replaced
Jul 16, 2012 | Robinair Cool Tech 34700Z Recovery,...
I'm Archie i've a Robinair 34988 just five days old and having problem with it. It keeps displaying HIGH PRESSURE (HIGH PRESSURE RESET). whether you try to vacuum,recharge, refill or anything...
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank).
After doing above stapes and your problem still exist then you have to replace PCB relay board. Just claim for warranty (Air purge solenoid and PCB relay board) from where you bought the machine.
Hope this will help to solve your problem, if so please vote for it for farther help! Good luck
May 16, 2011 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 and when i tunr it on it shows a massage "hi pressure "
Hope this will solve your problem, if so please vote for it for farther help! Good luck
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
Robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
Nov 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34788, Will not fill (IVS) tank from source tank .... tried three different tanks from three different distributors ... Indicates that source tank is empty .. All brand new tanks.
Please check ''TANK FILL'' hose quick connector & ''LIQUID'' hose on ISV Tank & make sure both valves is opening properly.it sound like(one of those) close! If valves is Ok then check tank fill solenoid, it may need to rebuild or replace. If those are OK, replace ''TANK FILL'' Hose.
I hope this will help you to solve the problem, if so please vote for it. Gool luck!
Aug 09, 2010 | Robinair Cool Tech 34700Z Recovery,...
High presure rest on robinair 34788
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robinair 34788 machine having same problem.You can try the following 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Aug 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
1,704 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
