Question about Coleman Mach 15 Air Conditioner
My manual just says " Operation and Maintenance instructions for 7000 & 8000 series roof top air conditioners, how do I know its a coleman and a 7 or a 8000?
  • drodecap
    drodecap Jul 23, 2012
    How many BTU's is the Coleman 8000 series?
    President:
  • 2,047 Answers
If it says manual for 7000 or 8000 series then both series have the same mode of operation and the directions in the manual will be sufficient for both models.
To identify the make and model you turn the back of the unit usually it is supposed to be written underneath the product.My manual just says
The 8000 series usually looks something like this. If it doesnt look this way then it is a 7000 series.
Hope this has been helpful?
Posted on Jul 14, 2010
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
How many watts for coleman 7000 series
take amp draw off data plate and multiply by 120 volts equal watts
Aug 18, 2013 | Dometic Rooftop RV Air Conditioner
COLEMAN SHROUD REPLACEMENT 7000 SERIES
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Apr 15, 2013 | Coleman Air Conditioner Shroud Rv Roof Top...
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
Need to find schematic on coleman 7333c886 ac
http://www.rvcomfort.com/rvp/tech_info/manuals.php
This is the web site for Coleman AC's from RVP. Go under the service manual for the 6700, 7000, 8000 and 9000 series air conditioners and they should have everything that you need.
Hope this helps,
Jeff
Jul 15, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
171 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
