Question about Garden
How to adjust valves on a STIHL FS 110 4 stroke
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: Carb Adjustment on Stihl FS %%T LA Screw
Turn both screws clockwise, until they snug down. then turn them counter clockwise 1 1/4 turn. try starting. Make gradual counter clockwise turns, up to two full turns on each. (Settings on screws should not be beyond two full turns. ) Continue different combinations between screws until it starts. If you need further assistance, feel free to ask.
Jim
Posted on May 30, 2009
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
Wher can I find a free shop manual for stihl fs 110 r
Do you mean the operators manual, or the parts manual.?
http://www.mediafire.com/download/crnkf8e983bccx5
If you find this is what you're after, please click the 'helpful' tab
If its the owners manual you require, please get back to me.
May 21, 2016 | Stihl Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Why Two stroke engine stihl streamer does'nt start when hot?
Sounds like a coil issue. When it happens again, check for spark immediately. If you have no spark, replace the coil.
Sep 04, 2014 | Stihl Garden
FS-55 R starts good, will not rev up what gives?
Its a lean condition. Check the fuel in tank. Be sure its fresh and water free. Use good 2-stroke oil. Check fuel filter and check fuel line outside of tank for cracks. If all checks out good then give lo speed jet 1/2 turn out and try. If adjustment is ineffective then rebuild the carb using Zama RB100 kit.
Aug 22, 2014 | Stihl Garden
I have a stihl fs 85 whipper sniper will start if i pour fuel in carby but doesnt seem to be sucking fuel into carby
Could be a dirty needle and seat, gummed up over time. Or an incorrect float or punctured float. Clean the carb and rebuild it wit a kit from your local dealer.
Aug 06, 2014 | Stihl FS 85 Weed Eater
Oil to gas ratio in the stihl fs 88 brush cutter
Hi, 25 to 1 with normal 2 stroke oil or 50 to 1 with stihl 2 stroke oil. Regards Phil.
Aug 14, 2011 | Garden
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Cuts out on acceleration
if you have over 200 hours on this FS 80 then you may need a valve adjustment(yes this 2-stroke has valves). if you wanna try to do it yourself it should be set @ 0.1mm @TopDeadCenter. my advice is take it to any stihl dealer and let them do it. its scheduled maintenance
Jun 15, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
828 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
