Question about Paasche Talon Gravity Feed Airbrush Set
My paache talon is feeding paint back threw where the air button is. did i loose a seal??? cant figure it out
2 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: Talon - I am trying
Try using a slower drying paint. Clean out the gun thoroughly and filter your paint through a bit of nylon stocking (hose), also make sure that you have sufficient pressure to supply a constant fine spray.
Posted on May 09, 2011
Air feed through gun with out touching the gun
take and screw out your top knob which is your fan control and clean it and also make sure none of the rubbers and seals are cracked, it might be possibly out of adj, but probably just dirty with old paint, clean it out really well with pipe cleaners or brush with paint laquer thinner
Sep 16, 2011 | Binks 54-1341 Air Valve Assembly For 7...
What is the best setting for spraying dupont imron urathane enamel with the 92s activator
because you used activator so the paint will be dried fast, therefore u probably want to paint it in a fast pace. set inlet air pressure at 2 bar, fluid control all the way until the trigger is loose. fan all the way open. paint it closer then normal and move fast.....i dont use activator but that's probably how i would do.
Sep 05, 2011 | Binks Model 7 Conventional Suction Feed...
The seal is damaged on the needle and letting paint travel back along the needle back to the trigger area. .
The trigger assy. will have to be taken apart to replace the seal on the stem. Be sure to check the trigger pin for smoothness where the seal has been sealing. Replace the trigger pin if worn or your new seal may leak.
Dec 01, 2010 | Porter Cable ExCell Siphon Feed Spray Gun...
I cant decide between two airbrushes i am thinking on ordering.I want a large cup gravity feed and right now am debating between the Badger 100LG and the Paasche Talon.Any comments would be great
I am not familiar with either brush, but they are both well known name brands. The Paasche will probably have more readily available parts for it than the Badger in case something breaks or you drop it. I myself use Iwata, BUT the parts are expensive.
It will boil down to which brush comes with what size tip/needle in accordance to what type of media you will be shooting. Thicker paints or stains will require a bigger tip and needle, thinner paints and stains, just the opposite. I hope this helps.
Feb 21, 2010 | Paasche Talon Gravity Feed Airbrush Set
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
I have a Talon electric line trimmer AT2309A and cant even seem to move the starting button to get it to work. Please help.
You need to move back the safety button on top of handle first. The safety button can be a bit stiff to move.
Nov 07, 2009 | 2006 Eagle Talon
Paasche Talon Gravity Feed Airbrush Set Logo
52 people viewed this question
Top Paasche Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you a Paasche Air Tool and Compressor Expert? Answer questions, earn points and help others
