Which usb port do I use for charging my ipod? Any of the 4 down the front or the one on the up in the middle by itself?
    Guru:
  • 1,342 Answers
Anyone will work.
Posted on Apr 20, 2008
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
The receiver doesnt light up when pluged into the usb port
sound like the receiver is down try other usb ports to charge your ipod if it works well it is your new mouse receiver thats capoot
Apr 18, 2009 | Computers & Internet
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
Nov 13, 2008 | Apple iPod nano
Infitek shuffle ipod
Greetings bernince24,
Generally when an Ipod is charged, it is off and connected to a usb port with your computer. It simply draws power off the computer. It is all pretty intuitive, plug and play. Meaning the once you hook the ipod to whatever charging device you are using, it will charge on it own from there.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Apple iPod shuffle MP3 Player
IPOD WON'T TURN ON
try holding down the middle button and the menu button at the same time for about a minute then it should restart itself
May 18, 2008 | Apple iPod nano 2nd Generation MP3 Player
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
İpod nano not seen at explorer and itunes
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
Aug 25, 2007 | Apple iPod nano
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
