Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
I have Bissell 7920. The water is not being
I have Bissell 7920. The water is not being sprayed just the soap!
  • 276 Answers
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Posted on Jul 15, 2010
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can't get the water to spray out when I turn it on?
When it doesn't dispense water or solution that means that the pump belt needs to be replaced. You can get a replacement and view the manual here:
Bissell 7920 Pump Belt and Manual
Dec 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
The 7920 is a 220 volt version of the 7901. I found a shop in New Zealand of all places that has service manuals on line. They are sort of picture books, but using them has saved me a lot of money as it makes repairing much easier. Here's the link you'll need. Good luck. If you need any more help, just add a comment to your post and it will go to my e-mail and let me know. The heads you clean are just the outlet spray heads when they get gunky.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Looks like you already have the USELESS Bissell advice list!
Jun 03, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water and soap coming out wheel area
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell won't release soapy water solution
heatman101
hjf
Nov 14, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 doesnt spray liquid
Ive oredered the pump belt and brush. after receiving and fixing them i will test the spray if it works.
Aug 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
196 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
