Question about KitchenAid KUDC25CH Dishwasher
Front door leaking at bottom left side
Front door of Kitchenaid dishwasher is leaking at bottom left side. Needs 3-4 inch high pan under it to catch a substantial amount of water as it leaks. This just started over last two uses and is apparent in the washing and rinsing cycle. I checked that the float valve in the machine appears to be free to move up and down and does not appear to be blocked. I removed the kick plate and watched the water leak through the bottom of the door on the left to center side facing the machine.
5 Suggested Answers
  • 250 Answers
SOURCE: KitchenAid KUDM25SH sprays water from under door at start up
Make sure the area where the door and bottom of the dishwasher meet there is not a buildup of debris. Inspect the dishwasher's gasket and make sure it's intact. It is pretty common to need to replace these. Finally, unscrew the little service door on the bottom of the machine and stand back and watch it for an entire first cycle. It might be squirting out of a slightly cracked pump housing that only leaks when subjected to the stress of startup, the water valve could be leaking when it opens to fill machine, or something else could be leaking. Make sure the wash arms are not damaged, are rotating freely, and don't have anything stuck in the jet holes.
Posted on Sep 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher model SHV6803UC/12 - washing
Welcome to FixYa.
I`ll start by letting you know there are many things which can manifest in the manner you`re describing...or even how one interprets what you`re describing.
Having said that are you referring to water in the tub or in fact the "pan" also known as overfill basin ?
**before performing any repairs please turn off the power to the dishwasher...safety first**
In either case I would instruct you to start by checking the drain hose where it is connecting to your home plumbing...i.e. under sink or into food disposer/garberator. for kinks or obstructions.
Also remove the filter assembly and check for food or soap deposits clogging the sump assembly.
**ultimately it may in fact be a faulty drain pump not pumping the adequate volume of water for the time allowed...but I certainly would check the drain first**
That is by far and away the most common cause behind the problem you are describing...based on my understanding as I mentioned.
Let me know if indeed this was helpful or not and we can move forward from here.
Either way thank you for choosing FixYa today. I`ll watch for your reply.
Regards,
Macmarkus :)
Posted on Sep 22, 2010
  • 441 Answers
SOURCE: I have Kitchenaid dishwasher KUDL03,
You need to do a vinegar wash, the film you are getting is from a change in detergent. many states have now outlawed phosphates in detergents, when the new stuff meets the old that is still in your dishwasher lines it makes the film happen. Fill a cup with vinegar and place it on the upper rack, then run it with no other dish's in it on heavy duty, the water will be displaced from the cup during the wash and will help to stop the film. I had to do this 7 times before the film stopped, good luck
Posted on Jan 21, 2011
allbrands
  • 600 Answers
SOURCE: I have a kitchenaid dishwasher
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
Posted on Jun 12, 2011
Bosch dishwasher will not take in water after cut off and restore of external warm water supply. Pump runs, aqua stop slightly warm and red tap /faucet signal comes on. Tried tilting.
your dishwasher is leaking water. the bottom or base of the unit is like a big catch pan, the pan has a water sensor witch is two metal contacts positioned just over the bottom of the pan. As water from a leak begins to fill the pan and makes contact with the two metal tabs it opens the circuit to a cut off switch at the water inlet valve. Slide the unit out from the cabinet just far enough to access the sides, about 20 inches, As water is removed from the panand no longer making contact wit the water sensor power will be restored to the inlet valve, Now you begin looking for the source of the leak, You may need to start a wash cycle, this is why the unit needs to remain connected. The source of the leake will dictate what needs to be disconnected and position of the unit. Something like the water level sensor can be replaced without fully uninstalling the unit.
Aug 18, 2015 | Bosch Dishwashers
Hi. My dishmaid dw12 sometimes leakes water. ive checked the water inlet and draing and its not that. what could it be
If the water is appearing at the front of the dishwasher during use, it's most likely that one of the door seals needs replacing.
There is a white panel, about 4 inches high, below the door. Stand to the side of the washer, open the door about half-way, and have a feel about on top of that lower panel. If it's wet, it's almost certain one of the seals is perished - usually the bottom door seal. This seal isn't visible like the goal-post seal that runs around the sides and top.
Also, food waste can build up on or under the seals and cause leaks.
If the water is appearing from the back or under the washer, then further investigation is needed and you may need an enginner. It's hard to be definite as you haven't been very specific about where and when the leak occurs.
Oct 18, 2010 | Dishwashers
Leaking from bottom middle and right side of door
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
May 11, 2010 | Frigidaire PLD2855RFC Dishwasher
I have a kitchenaid refrigerator kbfs20et that leaked
Yes it can and it also can confuse refrigerators with electronics. Think it is great you caught on the first time around. I have pictures of that happening to a Samsung and there was Ice in places I had never seen before. Yes if the refrigerator is near defrost and you leave the door open it will continue to try to cool and the compressor will run until the temperature is finally satisfied and the amount of water will be huge and overflow the condensate pan. Sea Breeze
Mar 15, 2010 | KitchenAid Architect® II KBFS20ETSS...
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a kitchen aide dishwasher ~ only about 6 yrs old ~ and it's the higher end model with the Wood panels , anyway , Its leaking water on the bottom ~ Is that the main seal ? and How hard is it to...
Hi
Thanks
Rylee
Sep 15, 2009 | KitchenAid Dishwashers
KitchenAide Dishwasher KUDS01FL leaks water
i have had mine leak (usually out of the left side) I can see it coming off the black rubber seal that ends about 2/3 of the way down the side. ( I have also replaced the inner seal around the tub- that helped as the bottom of the seal would stick to the door when closed and make a gap for water to come out) I also notice that water and moisture comes out at the top of the dishwasher (then it leaks down the side and front) I have heard of many problems with the latch...and I can push mine closed tighter but it doesnt close completely with just the latch, but enough for the wash cycle to work. also just make sure there are no crumbs or something stuck around the liner. good luck mine has been a lemon and i cant wait to get a different brand.
Jun 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
144 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
