Question about Xerox DocuColor 240 All-In-One Laser Printer
My docucolor 242 say an error 042-326. I need instruction to fixed.
5 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Xerox docu color 252 error
Hi
Error code 045-326 in your Xerox Docu color 252 means belt home position too long. To solve this first try NVM reset:
1. Hold down 0 (zero) key for 10 seconds and then press the START Button.
2. Then Enter 6789...confirm
3. Press Log in/Log out Button or the Key Button
4. Press System Settings, common settings, Maintenance, NVM Read/Write
5. Enter NVM 741-105 and change it to Zero (0)
After this if the error returns then check that the Transfer belt is in center...this belt is located beneath the drum cartridge. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 14, 2011
zeroxparts
  • 15 Answers
SOURCE: Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Posted on Sep 08, 2009
SOURCE: xerox 242 fault code 042-326
foult code 093-317
Posted on Apr 27, 2010
chdineshch
SOURCE: Xerox DocuColor 242 Fusor Error/ Paper Jam
I have problem with Fusor for Xerox DocuColor 242, paper has jam no error code but problem is after print one paper 270gram its was jam
Please help me what to do
Posted on Jan 08, 2013
Xerox docucolor 252
http://www.support.xerox.com/support/docucolor-242-252-260/support/enus.html?associatedProduct=dc242-252-260-built-in-controller
Replace any new toner you put in the machine and shut it down for 2 min then power back on. If that doesn't fix it you will have to call Xerox service to replace a sensor that may be broken.
Jan 03, 2014 | Xerox Office Equipment & Supplies
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox DocuColor 240 All-In-One Laser Printer Logo
406 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
