Question about Electrical Supplies
Remove Dimmer Backlight? We don't like that the Lutron Diva dimmers come with a "locator light" which means the dimmer is backlit when it is off. Can we just simply remove the small neon bulb in the dimmer? It seems like we could, but I called Lutron and they said that it would violate the warranty. If we are willing to forego the warranty, can we remove the backlight bulb without affecting the performance of the dimmer? Thanks for your advice on this.
  • 553 Answers
What your suggesting would work but it's highly probable that you would ruin the switch in the process. I retired (electrician) several years ago and I'm not 100% familiar with this particular model but I would be willing to bet there is a neutral wire running to the switch in order for that light to work. This neutral shouldn't be needed for the rest of the switch to work. If Lutron is still using the same color coding on their wires, black should be power in, red should be the switched power and if there is a white it's strickly to allow running the special features of the device. Be sure to turn the power off before trying this, as much for your safety and to keep from damaging the electronic built into many Lutron devices.
Posted on Jul 14, 2010
WHEN DIMMING IN MINIMUM POSITION THE LIGHTS START BLINKING
Which dimmer do you have. So I can look up the manual.
Are you using a fan dimmer, or light dimmer?
Does the dimmer feel warm to touch? or hot?
What does the dimmer control? Incandescent? Fluorescent?
How many total watts are being dimmed?
Is this a new dimmer or old dimmer that started having a problem?
Add a comment with as much detail as possible for best available answer.
Sep 08, 2012 | Lutron DVF-103P-277 Diva Fluorescent...
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
How do you remove the existing wires from the DIVA-600P light control. They are not screwed in, rather they are pushed into the back of the dimmer
You have 'quick connects'
Next to hole where wire goes in, is slot for small screwdriver.
Push screwdriver in real firm while pulling wire.
Nov 12, 2010 | Lutron Diva Dv-600P Light Control By
We don't like that the Lutron Diva dimmers only come with a "locator light" which means the dimmer is backlit when it is off. Can we just simply remove the small neon bulb in the dimmer? It seems like we...
The dimmer's performance would not be affected by removing the neon lamp. However, it will be important to snip the leads so they don't cause a short in the circuit board.
You could just use some high-temperature black paint and coat the neon lamp.
Jul 14, 2010 | Electrical Supplies
I need to install a diva low voltage electronic dimmer. An incandesent dimmer was previously installed. lights flickered. There are 4 wires on the dimmer. (green black whate and yellow) I know what to do...
The dimmer connections should go like this.
Black from dimmer to black Constant Power In Wall
White from dimmer to Neutral (Whites) in wall
Yellow from dimmer to wire out to light (usually black)
Green from dimmer to BARE GROUND WIRE
May 08, 2010 | Lutron Diva Electronic Low Voltage 3-Way...
Lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Mar 30, 2009 | Lutron Electronics Diva 3-Way Duo Dimmers,...
Electrical Supplies Logo
122 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
