Question about Whirlpool Ovens
The display and all oven functions are not working
The display for the oven and all oven functions are not working, but the electric range and controls ARE working...any ideas on what may need to be fixed?
    President:
  • 1,891 Answers
With out a display it hard to set oven tempt ect . you will have to replace the e r c ( clock ) to correct problem .. mm
Posted on Jul 15, 2010
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not working
its probably repairable....most of these touch pads are able to be replaced from your local appliance repair centre.
Jul 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
Oven stops working and display screen goes blank
Hello The control has developed faults in one or more of it's circuits. This clock/timer must be replaced to solve the problem. The Good news is that this is not one of the really expensive controls. Found this one for about 70$ at a website. Worth fixing- but beware the 'self-clean' function after repair, and this control should last a lot longer.  Please acknowledge this post if info helps- have more if needed- Thanks- Ed
Mar 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I got an F7 error code and now the display is blanked out. JTP20 series wall oven
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Nov 25, 2009 | GE JTP20 Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
88 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
