Question about Electrical Supplies
We don't like that the Lutron Diva dimmers only come with a "locator light" which means the dimmer is backlit when it is off. Can we just simply remove the small neon bulb in the dimmer? It seems like we could, but I called Lutron and they said that it would violate the warranty. If we are willing to forego the warranty, can we remove the backlight bulb without affecting the performance of the dimmer? Thanks for your advice on this.
  • 744 Answers
The dimmer's performance would not be affected by removing the neon lamp. However, it will be important to snip the leads so they don't cause a short in the circuit board.
You could just use some high-temperature black paint and coat the neon lamp.
Posted on Jul 15, 2010
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
Our lutron dimmer switch only has a yellow light and no green light. It obviously will not turn on any of the lights it is connected too. We have flipped all the breakers and everything is good. All the...
I would call their tech support center for clarification, because what you descirbe doesn't immediately make sense. The only light that a Diva has should be a yellow glow through the back of the plastic. If you're talking about a green light, then maybe you mean a Maestro, but there's no yellow light on a Maestro... it's making me think you may have a different manufacturer.
Regardless, call tech support to figure it out. They're at 1-800-523-9466 and available 24/7.
Dec 15, 2010 | Lutron Diva Dv-600P Light Control By
Night light in lutron wall switch flashing can it be fixed and how
Unfortunately, no. Its a neon bulb that gets soldered into the product, so its not something that can be tweaked or replaced. My suggestion would be to call their tech support number 1-800-523-9466, and see if you can get them to replace the whole dimmer.
Nov 10, 2010 | Lutron Almond - Diva Incandescent Dimmer...
I need to install a diva low voltage electronic dimmer. An incandesent dimmer was previously installed. lights flickered. There are 4 wires on the dimmer. (green black whate and yellow) I know what to do...
The dimmer connections should go like this.
Black from dimmer to black Constant Power In Wall
White from dimmer to Neutral (Whites) in wall
Yellow from dimmer to wire out to light (usually black)
Green from dimmer to BARE GROUND WIRE
May 08, 2010 | Lutron Diva Electronic Low Voltage 3-Way...
Lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Mar 30, 2009 | Lutron Electronics Diva 3-Way Duo Dimmers,...
Electrical Supplies Logo
282 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
