Question about Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face
My light is not coming on...I have reset my GFCI and still does not work. How can I tell if it is burned out? I thought the light would last longer than 3.5 years. It has not been used that much.
Mine has the same problem. I figured out that the lense cracked allowing water in and shorted out the PCB board that has the LEDs on it. Dried the board off, tried it again, it powers correctly intermittently. Still working on the problem.
Posted on Mar 09, 2011
My hot tub has been running perfectly until a few nights ago when the GFCI breaker tripped and now it wont reset
Either you have a ground fault or the GFCI is toasted. Turn off the power to the GFCI, open the box the GFCI is in and disconnect the output wires, close up the box, re-energize, and try to reset it again. This will tell you which problem you have.
Jun 04, 2012 | Cutler Hammer CH250 2 pole 50 amp
How to reset Culter Hammer GFCB115
Hi Tenny,
I'm an electrician and can help with this problem. First, did you just install this breaker - or was it working before? If you installed it - skip down to the end.
If it was working before, I can tell you that resetting a GFCB115 is the same as any other "regular" circuit breaker in the panel:
1) Clear the source of the fault.
2) Push the breaker handle from the "Tripped" (or mid) position to "Off"
3) Push the breaker handle from "Off" to "On"
That's it. Most times, people skip #1 and go right to #2. If the breaker handle fails to remain in the "On" or immediately moves to the "Tripped" position after or during a reset operation, one of two things is wrong: 1) The breaker is defective. This does not happen that often - but it does happen now and then. 2) The offending load has not been cleared. This is more likely to be the case. Start by trying to isolate the source of the fault which many times is the most recent device connected to an outlet. One by one, unplug the devices on the circuit and power up to see if the breaker "holds" the load without tripping. Once it holds, it is a safe bet that this last device is the source of the problem. Reinsert all the plugs back into the outlets - except the last one. If the breaker is still holding, the device that was left unplugged is probably the culprit and will need to be checked out before connecting again. It is NOT advised to simply use the device on a non-GFCI protected circuit. There is probably an issue with the device - and it will be present on the non-GFCI circuit that could result in shock, burns or loss of life.
Keep in mind, most GFCI circuit breakers will trip when a ground fault or a current overload is detected. There is no distinction or indication if the breaker tripped due to one condition or the other. If it has tripped due to overload, clearing the fault is done by simply reducing the load on the circuit. Once the load is reduced, the breaker will reset normally.
If you just installed it and it won't work, tell me how you connected it to the panel and how you connected the circuit to it.
I hope this helps and good luck!
May 02, 2012 | Eaton Corporation GFCB115 GFI Circuit...
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
I have 2 gfi outdoor outlet with orange lights on and cannot reset
GFCI is designed to detect ground faults, and will not reset if ground fault is detected, or if device is bad.
Seems odd that both GFCIs will not reset unless both are outside.
If GFCI is outside, they get dirty and wet, and the GFCI goes bad.
If GFCI will not reset, open following links:
http://waterheatertimer.org/pdf/GFCI-outlet-will-not-reset.pdf
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 18, 2011 | Leviton 8599 GFCI Receptacle
Jacuzzi wont turn on. It is making a hum but not working. Tried resetting GFCI many times, same result.
it sounds like the motor is burn out especially if the gfci keeps tripping when u try to turn on
Jan 12, 2011 | Home
I have an electrical circuit in my home that consists of five outlets serving 2 and 1/2 baths, and one of which is a 20 AMP GFCI. The GFCI needed to be reset almost daily until it could no longer be reset....
They put the GFI in line at the front, all the other plugs run off it. One of the other plugs, has lost ground, has lost neutral, a simple plug in tester will tell you this, find the fault, or,, you have a fluorescent bulb plugged into it. The gfi's are very sensitive, they snap at the drop of the barometer.
Mar 14, 2010 | Leviton 8599 GFCI Receptacle
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Timer doesn't come on after being set. Operates landscape lights
Check your circuit breaker that feeds the timer circuit in your main electric panel. It may have tripped. Sometimes when a breaker trips it's hard to tell visually, so turn the breaker off, then back on.
Also, the circuit that feeds the timer may be on the load side of a GFCI receptacle. Look for one that has tripped. Sometimes they are found in obscure places.
Apr 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face Logo
696 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
