Question about Kenmore 27032
Kenmore washing machine does not click into rinse or spin cyle, only aggetates
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jul 14, 2010
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
My Ge washer will not spin or rinse either. The
Being that it's a G.E, slide the machine to the side. Do you by chance see oil under the machine? If so, the gearcase (transmission) is shot!
Feb 10, 2010 | GE WBSR3140DW Top Load Washer
Kenmore model 110 23832100 stps after wash cycle before the rinse cyle. The old water has not drained.
If the machine fills, and washes and won't drain or spin out the water you need a direct drive coupling. It is located at the bottom and is on the motor shaft and consits of 3 pieces. Check this first, easy fix and not expensive.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
Amana washer LWA50AW
I had the same issue last year on y lwa50aw. It is the timer. Get the speedqueen version it is about $50 -$80 and aboyt 15 minutes to replace.
Apr 19, 2009 | Amana LWA40A
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Kenmore Oasis Spin Cyle Extremely Loud
Your probably right as most washing machines use bearings and they do wear out rather quickly on some machines ,depending on how yours was put together will determine on how easy it is to change , some manufactures made it much more easy than others .If you remove the back panel (that's if it has one )and after it has gone through its spin cycle and you have turned of the power you should be able to feel around where the bearing is incased to see if it has generated an amount of heat even though they are usually encased in oil as this would be a indication that it has failed, if you watch the machine clicking into spin mode ( by looking at the motor etc with the back cover removed)you will also get a better idea as to what parts have come into play and pinpoint the problem area .
Aug 07, 2017 | Kenmore 27032
Maytag washing machine
humm, is it advancing to spin on its own or are you manualy moving it?
model serial is on the top of machine stand on tip toes and look over the top
could just be the lid switch
May 16, 2008 | Washing Machines
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 27032 Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
