Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My washer will only spin when it is empty. The
My washer will only spin when it is empty. The washer will not spin with inside the tub but the motor runs. If I take the clothes out of the washer then it will spin. If I put clothes inside the washer the motor just runs. Do I need a new motor?
catriver
  • 878 Answers
SOURCE: Washer will not spin
Josh, sounds more like the drive block or spin tube that is at fault. I will attach photos of each...Catriver..post back.
Posted on Oct 13, 2006
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Posted on Dec 23, 2007
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
I have a wtw6600sw2 giving a f-51 code. I replaced rps sensor and harness and control board. Still giving me f-51.Also there is nothing between the tub, tub turns freely.
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa!
Feb 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displays error code 51
Jan 07, 2011 | Washing Machines
I have a kenmore oasis he 262072 washer that has an f51 error
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Jan 05, 2011 | Kenmore Oasis HE 27062 Top Load Washer
Please, in my washer appear the code F51. What is it? What is the matter in my washer? Thanks
Thanks for using FixYa!!
Dec 09, 2010 | Washing Machines
Lid switch is brokem will this cause my washer not to empty water after cycle
Sure will. Why? Because the pump is mounted on the drive motor. If the lid switch is bad the motor won't run. If the motor don't run the pump won't pump. The motor goes both directions. In one direction the water is retained in the tub and the gears inside the tranny agitate the wash. In the opposite direction the water is tossed out and in some models a neutral pack is installed. That allows the pump to remove the water before the tub has to turn. When the pumping is timed out the power is killed momentarily and the spin pawl gets released. When power is resumed the spin pawl catches one of 3 bosses under the main drive gear. This make the drum spin. Clever ain't it? I have 2 movies Got popcorn? LOL the first vid is how to get inside the washer (cause they ain't all the same) The second show the lid switch replacement:
May 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore he washer getting an F 51 code and washer quits just beeps
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jan 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F51 code
May 15, 2009 | Kenmore Washing Machines
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Washer go though all cycles but no spin
the motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Aug 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
222 people viewed this question
Dan Webster
Dan Webster
Sal De
