Question about Cameras
I am unable to find instruction booklet so i can adjust brightness & darkness an set clock. Could you please advise or send me a copy of instruction booklet
  • kakima Jul 14, 2010
    Perhaps. Would you care to specify the make and model of your camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Sep 08, 2010
How do you get the display light on a bose radio to stay on
Do you mean keep it from going dim in a dark room? The settings menu has "Bright Hi" and "Bright Lo" adjustments you can make in ranges from 1-8 (Lo) and 8-10 (Hi). Check your manual under the heading "The setup menu" for very clear instructions.
Jul 03, 2014 | Bose Wave Radio
Missing booklet from my DVD order of Dark Shadows
Tell your supplier Amazon. Not us. We are not affiliated with them.
Jun 22, 2017 | Video Game Consoles & Games
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
Would you please advise how to adjust the brightness settings.when i go to the menu button i can get the various settings but i am unable to make any changes.please advise. thanks
Hi; the upper part of your keyboard closest to the screen or the last row of keys contains a BRIGHTNESS key...
Press and hold the Fn key (usually italic and purple color) and press the Brightness (sometimes depicted by a bright bulb) key and observe if there's a change in brightness...remember to hold down the Fn key while adjusting the brightness. I hope this helps since you did not mention computer type or keyboard arrangement!
Jan 23, 2010 | Hyundai Computers & Internet
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Instruction booklet
Hi - You can download the manual from the link underlined in blue below:
XCTI VPC-S60
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 22, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
