Question about Coleman Mach 15 Air Conditioner
AC runs for 10 minutes than it trips the breaker. Tried it twice same thing is my compressor bad?
  • martinezbobb Jul 14, 2010
    Yes it was im at work im going to try your advise when i get home.
  • 553 Answers
If, I assume it's been running fine up until now. I would first suggest checking the electrical connections to make sure none of them are loose. Be sure to check the breakers connection to the bus in the panel this is a common problem with most brands of breakers. A loose connection can cause the unit to pull more amps causing the breaker to over heat and trip. The next possibility is a bad motor run capaicitor which would cause the unit again to drawn to much current and cause the breaker to trip. Finally I would check the compressor to be sure it's not low on oil causing the motor to work to hard and once more cause the breaker to trip.
Posted on Jul 14, 2010
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
Jun 07, 2017 | DeLonghi Heating & Cooling
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
AC Runs for about 10 minute then trips breaker
is your breaker is ok or lose concation is good.if this both is good than cheek his overload.
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Breaker switch tripped when ac compressor engaged
The power strip is rated too low for the wattage of the unit and that causes the breaker to trip. I would be better for the unit if it were plugged directly into a wall outlet, because there is less a chance of voltage drop which would burn out the unit. They will only tolerate 10% voltage drop before getting into trouble.
Jul 02, 2009 | Fedders A6P09S2A Air Conditioner
The unit runs fine for a couple of days then trips. some time it will trip twice a day
The compressor may be old or the starting capacitor is weak. Could be bad connection on the AC supply line or pitted contacts on the run relay. Check all AC wiring supply connections even in the house electrical panel for tightness, Replace the starting capacitor first.
If it still has a problem install a hard start capacitor kit. Could even be a bad breaker - breaking out on a lower current draw.
Jun 20, 2009 | Ruud UAKA060 Air Conditioner
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
120 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
