Question about iLO Televison & Video
The red led light keep flashing and the tv won"t come on when i push the power botten or use the remote
  • 10,515 Answers
Unplug the TV for few minutes, say 30 minutes and then ON the TV.If the problem persists, it would almost confirm a hardware problem.If you have experience in repairing TV's. could read schematics, have experience using multimeter and could keep precautions :-
1. Model of the TV?
2. Is there any sequence of blinks? If yes, kindly let me know !!
3. Color of LED?
4. Is there any other symptoms like clicking noise or smoke?
Let me know,so that we could proceed.
Thanks!!
Posted on Jul 14, 2010
  • gab9594 Jul 14, 2010
    i did unplug the tv and then plug it back with no change it seem by what you told me i may have to seek help can ypu give me an idea what this might cost
  • taran_2005
    taran_2005 Jul 14, 2010
    Thanks for your response!!
    This is a really subjective in nature. The symptoms that you mentioned are highly suggestive of ' power supply problem '. It will take a technician removing the back of the set and measuring the voltages coming out of the power supply to confirm my diagnosis. The problem is that the set is so inexpensive that the repair costs are likely to be nearly the replacement cost of the set. Labor for troubleshooting doesn't come cheap, and unless you can find a trade school or some other source for technical help, it is liable to be best to replace the set. I wish I had better news, but the track record for this set is not good.
    Cost - On an average, could be anywhere between $175 - $300 ( max ) depending upon the fault and the technician. A small shop would cost you less than a large facility repair.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
When trying to set up my new SRP2008B remote should the TV be on or in standby mode? In step 2 should the red LED be flashing or stationary? The Quick start guide is somewhat ambigious about these two...
U are setting up a universal remote?Yes,tv should be on,second push the search button on the remote,should be flashing and enter all those codes provided by the manual one by one the LED light of the remote should be solid red as the codes enter one by one the red light and go off and pushing the on/ff button on the universal remote for each codes as u got the wright codes the tv will turn itself off.
Apr 11, 2011 | Philips Televison & Video
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
