Question about Minolta EP1031/1031F CS/PRO Copier
Minolta CS/Pro 1031 Refuse to work and display PC
My minolta CS/Pro 1031 doesn't want to work and display PC when I press start botton. I need your help to fix this problem.
  • 1,110 Answers
Check your paper supply in the paper tray. PC means the machine thinks it has no paper or the paper did not feed. If making sure the paper is good and loaded properly does not solve the problem then pull out the tray completely and clean the rubber feed rollers inside of the port where the tray came out off. They should be about half way to the back and over to the right side. Most common cause of this problem is dirty/dusty feed rollers that are not pulling the paper up into the machine. Just wipe them down with glass cleaner of even a cloth dampened with water.
Good Luck and Thank You for using Fixya.
Posted on Jul 15, 2010
How to reset code c0050 on minolta 1031
press the motherboard reset button .This error for abnormal temparature
Jun 22, 2014 | Minolta EP4000/5000 CS/PRO Copier
How to resolve erorr code c0100 minolta cspro ep4050? spdhandri@yahoo.co.id
ckeck the main motor but try reset first the error to reset that error open the front door then at the left side of the machine you will see the small square attach with 1 screw remove that screw then the plastic square type then you will see the reset botton just press that botton
Dec 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code c 0500
fuser problem to rest this code you need to turn on the machine and open front cover then remove one small cover in the lift side machine you will find small botton black color (trouble) press it
Aug 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
Apr 06, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Giving code of "C004A". What does that mean?
A C004a code is a error code with a fan in the copier. It is either not working or is making a noise. You may be able to hear the affected fan and try to lubracate it. There is a Trouble reset botton behind the cover of the display contrast knob. Its on the inside front cover above the fixing unit. Try to rest the code there first. Good Luck
May 04, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code c40
I believe a c40 is the trans port sucation fan.... It is under the trans port belts. Did you try to reset the code? The Trouble rest botton is behind the display pannel control for brightness. Inside left side above the fixing unit.
Feb 03, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP2030 shuts off immedietly when I power it on
Do you see a error code? Like a C5? Try holding the power botton on and look for a code that shows up on the display. You may have a blown heater lamp or scanning lamp. You are losing your AC power some where.
Jan 22, 2009 | Minolta EP1083 CS/PRO Copier
Minolta 1083
sound like fuser prob
if this a **** shell machine .there is a reset botton on CB in the back of the machine .
hope that help
Oct 08, 2008 | Minolta EP1083 CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
132 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
