Question about Troy-Bilt Pony Garden Tiller
Wont spark changed the coil and spark plug, it has new wires. just cant get a spark when i go to turn it over. any suggestions?
    New Friend:
Check flywheel sounds like keymay be broke
Posted on Mar 08, 2013
98 harley fatboy turns over but wont start
some after market ignitions don't spark on the first couple of turns but first take off your air cleaner twist the throttle and look to see if gas is spraying in the carb if not give it a little starting fluid if it fires but then dies then its carb issue. now other thing to check is if you have three posts on your coil then its single fire and your plug wires might be going to the wrong spot switch um around.
May 09, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
Wont start, engine turns strong, new battery, new plug wires?? Thinking coils are bad???
take off one plug wire from one of the coils, turn starter and see if a spark jumps, you will be able to hear the sparks if you are by the door turning the key. if you get no sparks the ignition module is bad, if you do get spark try same test for remaining plug wires one at a time. you may have a bad coil
Sep 23, 2011 | 1998 Pontiac Grand Prix
I have a stilh 250c chain saw, once it's hot and is turned off or stops it wont start until it's cool. I check the spark plug and the spark plug wire, I have also change the spark plug. It's...
hi
michon
sounds like you have either a tank breather problem or a ignition coil going o/ c when hot
check your tank breather for venting if its ok replace the coil and reset air gap at the coil / flywheel and fit new plug, remember to use loctite the the coil to cylinder mount bolts
and set air gap to 0.010 to 0.012 thou
let er rip
cheers pauly46
Sep 21, 2011 | Garden
Car wont start in the rain/cold weather changed everything electrcal wires /plugs /roter/ spark plugs /all sensors /still wont start cant go to work /do nothing
Check for fuel delivery problem by spraying starting fluid into the intake and observing whether it starts for a few seconds or not. If it does start, and dies, then the fuel pump may be at fault. If it doesn't start at all, check for spark with a spark tester off of one of the spark plug wires.
Dec 12, 2010 | 1995 Chevrolet Astro
I have a 1991 tzr 125 rk2 it wont start changed coil ,new battery,new ht lead and cap, checked pulsar coil just bought it and cant think of anything else getting a weak occasional spark but wont fire also...
Dirty contacts in the ignition switch contact base. You may not be able to disassemble and clean your switch but you can check the wires for continuity. Your handle bar kill switch can also be be a source of intermittent spark.
Sep 23, 2010 | 1990 Yamaha TZR 250
Car wont start
No spark, ck the crank position sensor. bolted on engine at the front crank pully. Good luck. unplug and plug it back in to clean the wire connection/
Jun 03, 2009 | 1990 Dodge Dynasty
Cant find the spark plug location on 2002 4cyl tacoma
Locate the spark plug cover on the engine.On some Toyota Tacoma engines, the cover is across the top of the engine. On others, it is along the side 4 cyl. Remove the cover to reveal the ignition coils and spark plugs wires. The spark plug wires are plugged directly into the engine and the ignition coils are in the tip of the spark plug wire.
Remove the coil and wire from the spark plug. Twist and pull the plug out of the engine. Remove the spark plug from the cylinder well with a socket extender and socket wrench. Turn the wrench to the left to unscrew the spark plug from the engine.
Discard the old spark plug and apply a coat of anti-seize compound to the threads of the new spark plug.
Insert the new spark plug into the socket. Use the socket and extension to screw the spark plug into place.
Return the ignition coils and spark plug wires to the engine and turn it to lock the plug in place. Repeat the entire the process with the remaining spark plugs.
Replace the spark plug cover when all of the spark plugs are replaced.
Good luck and hope this helps and The spark plug tension may range between 11 and 15 foot pounds, depending on the size of the spark plug. The correct tension is indicated on the spark plug's packaging.
Apr 19, 2009 | Toyota Tacoma Cars & Trucks
1996 S-10 cranks but no fire
did you check to see if fuel pump is pumping. fuel filter isnt clogged is it? but you're sure there is no spark. because if there is spark it could be air flow problems.
and you changed the ignition switch so that's not it, how about the starter. is there any noise coming from the starter when you turn key? if it isn't lined up right.
there has to be spark if you did what you said take off a wire at night and try it . electricity to start goes, ign switch battery starter(is there a relay on s10s cant remember), the alternator is here also.to coil/distributor to wires to plugs to gasoline
also it could be the wires coming from the battery , check them for corrosion. if they are really corroded could be problem. and make sure your ground is good contact. ive seen corrosion inside wires causing no spark.
just a few ideas to check.
Feb 25, 2009 | 1996 Chevrolet S-10 Pickup
No fuel or spark on my 89 chevy k5 blazer
change coil pickup which is in the bottom of the distrubuter
Feb 13, 2009 | 1989 Chevrolet S-10 Blazer
No spark, just put in a new coil, distrbutor isnt dirty or wet, sombody told to check out the littl box's on the fender well, what are these to box's and what is there purpose? Mike 77 cj-5 304 3spd I...
I had the same problem with my 85 cj7 this week, I relpaced the ignition control module, plugs, wires, cap, rotor and the the coil; still had no fire to plugs. the problem turned out to be my distributor, replaced it today and she fired right up. Most likely it was the pick up module in the distributor that went bad.
Nov 30, 2008 | 1983 Jeep CJ7
Troy-Bilt Pony Garden Tiller Logo
90 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
