Question about Refrigerators
My ge model gss 25 ifph cc is not refrigerating and is running constantly. I am losing food in both refrigerator and freezer. Can I reset unit
  • 13 Answers
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
mikedurland
  • 481 Answers
SOURCE: GE GSS 25QF Side by side Refrigerator
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 14, 2008
SOURCE: GE GSS 22KG SIDE BY SIDE REFRIGERATOR 6 YEARS OLD
The codensor fan is not running. I have the same problem. I had the fan replaced a year ago for the same problem, so I can't tbelieve it's the fan. I am guessing something on the circuit board is not letting the fan kick on. I don't have a definite answer yet, but the fan not running is the main issue you are having.
Posted on Sep 30, 2008
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
SOURCE: GE side by side refrigerator freezes food in the
no cold air gos in to frig side
Posted on Feb 07, 2010
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Freezer freezes and won't cool either freezer or refrigerator.
On my GE side by side (model GSS20IEMDWW), the evaporator coils froze over due to constant running of the compressor. The compressor was constantly running due to a faulty temp sensor in the fresh food side of the unit. The sensor was apparently reading too hot, thus never signalling the computer that it should stop trying to cool.
This could be what the original poster was attempting to describe.
Jul 26, 2009 | Refrigerators
The freezer is not freezing anything on my GE GSS 25 LGP side by side.
Do you notice frost on the rear wall of the freezer section 1 foot from the bottom ? If so , then defrost problem . If not , probable board problem .
Jul 17, 2009 | GE GSS25LGP Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Freezer not working
with min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Oct 12, 2008 | GE GSS25JEMWW Side by Side
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE model gss side by side refrigerator
I ASSUME YOUR TALKING ABOUT THE COILS BEHIND THE BACK OF THE FREEZER ..IF SO YOUR UNIT IS NOT GOING THROUGH THE DEFROST CYCLE BECAUSE OF A BAD HEATER OR BAD DEFROST TIMER OR BAD DEFROST T STAT .YOU CAN FORCE IT INTO DEFROST BY PUSHING THE FRESH FOOD DOOR SWITCH THREE TIMES IN 15 SECONDS IF YOU HAVE AN ADAPTIVE DEFROST TYPE OF DF CONTROL(ELECTRONIC TYPE).
Apr 02, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
