Question about Vacuums
I have a Hoover, Steam spin scrub, Model F5897-900. Only used it a couple times and the motor gave out. First started being noisy then a bad smell. It did seem noisier that what I would expect from the start but I didn't realize it was a problem with the shaft of the motor. I took it apart and found the motor shaft wasn't true and causing sparks. The motor looks like it can not be taken apart and repaired. This seems like a default from the beginning but it is past warranty. Also noticed that the hose for upholstry cleaning was installed improperly causing it to tear. If it had been placed in the right spot it would have given a proper length of hose to expand when opening the handle release. The machine otherwise worked well and I was happy with the cleaning job it performed. I was able to take the fan part of the motor off but did not see any way for further disassembly. It appears I will need a new motor including the mount as it appears as one unit. What to do???
    President:
  • 1,673 Answers
You will have to replace the motor and the hose asm. thehooverstore.com may be able to help, or you should be able to find a repair shop that can order them for you.
Posted on Apr 20, 2008
Looking for manual for the Hoover Steam Vac Carpet Cleaner with Spin Scrub Model F5906-900
Check out this link it may help
http://www.appliancefactoryparts.com/vacuumcleaners/brands/hoover/f5909-900.html
Jun 22, 2012 | Hoover F5906-900 Upright Steam Vacuum
I have a new hoover steamvac spin scrub. This was the third time I used it in the past ten days. I changed the water and added cleaning solution and when I turned it on it made a weird sound and died. ...
It sounds as if this machine has a defective motor. Usually a bad motor will fail quickly. You should have a 1 year warranty, so I suggest looking on Hoover's website for an authorized service center.
May 02, 2011 | Vacuums
The steam vac stopped working while in use and
If the cleaner will not turn on at all, you could have one of several problems:
(1) Bad foot switch
(2) Bad power cord, or
(3) Motor failure.
The unit would need disassembled and tested with a continuity meter to determine the part that failed.
Oct 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Do not know how to use Hoover Steam Vac Spin Scrub
Hoovers website, Hoover.com has them free to print.
Jun 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
60 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
