Question about HP LaserJet 2840 All-In-One Printer
I cannot get a genuine fuser unit here in Sydney Australia as the printer is obsolete. Any help please?? ian
    Novelist:
  • 170 Answers
Here ya go mate...
click here!
They're very reasonable... hope this helps and if so please mark Fixya...
Posted on Jul 14, 2010
How do I change out the fuser fixing unit on a Kyocera FS3900 DN
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the
fuser lock (gray colored) on the rear unit and
the fuser unit is separated from the rear unit
(rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all
the removed parts.
Place the fuser unit on the rear unit (rails)
and push the fuser lock so that the fuser
lock catches the fuser unit.
Do it for the both ends of the fuser unit.
Aug 08, 2014 | Kyocera Mita FS3900DN Fuser Fixing Unit -...
Samsung CLX-3175FN printer only prints VERY faint image. Just replaced all toners with genuine Samsung. Never had this problem. All contacts look clean???
Faint prints with Laser Printer usually occurs when the drum is full with the wasted ink (toner power) or when the Fuser Unit is not working correctly. First of all try cleaning the Drum and remove the wasted toner power. There should be an opening on one of the end of the drum. In some cases, it needs to be disassembled to remove the wasted inks.
Also remove the fuser unit and clean the unit. Please handle it with care and never clean it when it's hot/warm. Only do this, after the printer is left turned off for about half an hour.
If nothing is helpful, try with another/new drum or fuser, that will help you get to find out the exact cause of the problem.
Good Luck.
Thanks for using FixYa.
Sep 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Need a belt for singer sewing machine class no 201k where do you get one in sydney nsw
Please contact the Singer distributor in Australia:
Blessington Pty Ltd
Unit 17, 167 Prospect Hwy
Seven Hills NSW 2147
Sydney, Australia
Tel: (61) 29 620 5922
Fax: (61) 29 620 5933
URL: www.singerco.com.au
Email: info@singerco.com.au
Sep 21, 2009 | Singer 132QRFB Mechanical Sewing Machine
I have a 240v Ricoh AP3800C (Australia), but I have bought a few Fuser units from the US (110v. What do I need to have done to the fuser units to work in the Aust Model? A new thermister? new lamp? cost?...
Only the lamps, p/n AX430070 (pressure)
AX430159 (heat roll)
the watts of the lamps are the same, just different voltage, so no you dont need thermisters.
-Carl, please let me know if this helps.
Jun 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh 2018D fuse unit
You probably won't find one new, the model is to old, used is your best bet.
Jun 01, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool.  Then gently wipe off the surface of the photo-sensitive drum with a cotton swab.  If this doesn't work you may need to replace the drum.
Nov 20, 2008 | Brother MFC-9420CN All-In-One Laser...
Drive belts
totalvac.com
They ship international.
Nov 01, 2007 | Kirby Heritage II Vacuum
HP LaserJet 2840 All-In-One Printer Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
