Question about Cameras
I have a Pentax digital camera. Even after using a fully charged battery the camera shows that the battery is completely drained out after just 4 or 5 clicks. What can be the cause? And how can I rectify this problem? Please let me know. Thanks.
  • 687 Answers
You battery is faulty even if the voltage shows correct as soon as you load the battery ie. try to use it and draw current the voltage will drop sharply and show as discharged. You will need a new battery and make sure its on charge overnight for the first time you charge it.
Posted on Jul 14, 2010
The indicator shows low battery after 2-3 shots. (batteries 3800 MAh are fully charged)
This seems to be a problem with the ist line. My istD does the same thing. Turning it on and off a few times helps with mine. Pentax has no solution.
Sep 24, 2010 | Pentax *ist DL Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
It won't turn on even with a fully charged battery. What do I do? I've owned it for at least 5 years and have three batteries and a pentax charger that turns green when a battery is charged. I put the...
yeah if you have had it for that long the batteries might be dead even if the appear to be charged i would get new batteries or get a new camera get one cheap on eBay ! have a good day :)
Apr 01, 2010 | Pentax Optio 430RS Digital Camera
What type of rechargeable batteries are the best. batteries even when fully charged can only take 2 pictures .
The problem is not in the batteries....
I have the same problem, after two pictures the camera shuts off even when new batteries have been installed...
Aug 26, 2009 | Pentax Optio E10 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
Pentax K10D Both LCD screens are blank
Did you put a memory card in the camera?
My camera did this today, and I resolved it by putting a memory card in, but even when one has been out before it still turned on, so I'm not sure that is the resolution. Did you ever find out what was causing it?
Sep 29, 2007 | Pentax K10D Digital Camera with 18-55mm...
Technical problem
I purchased a *ist DS used a couple of weeks ago, and it turns out to have similar problems. This camera seems very fussy about batteries. I am using rechargeable NiMh AAs. After about 30-40 exposures, the camera shows battery depleted. If I turn the camera off, then back on, it will show a charge - sometimes a full charge and will work for another 20 or so exposures. It can keep this up for a couple of days.
I read an explanation in one of the photo blogs (can't remember which) that suggested this was caused by one or two incompletely charged batteries in set of 4. If one is discharged the current from the others supposedly will flow to it, giving fluctuating power readings to the power management curcuit. This sounded plausible enough that I purchased a new charger yesterday which monitors the charge on each battery. Too early to tell whether this solved the problem or not. The other option is to switch to disposable batteries.
Oct 09, 2006 | Pentax *ist DS Digital Camera
*ist D Grip problem
i have yet to recieve the b-grip for my *ist so i can't tell you if i have the same problem. i do have a thought on the matter and an interest in the fix as i have a grip on order. have either or both of you upgraded to firmware 1.1? that is not listed as something the firmware update remedies. however, i understand that manufacturers often include fixes for less conspicious problems without listing them. if you haven't upgraded it's worth a shot, you have nothing to loose as long as you use FRESH batteries. hope i helped. have fun shooting.
Sep 08, 2005 | Pentax *ist D Digital Camera
*istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
