Question about Simpson WS4050V Water Shotgun 4000 Psi Cold Water Electric Start Gas Powered Pressure Washer W/ Vanguard Engine
Not sprayer engine stop
My pressure washer turns off when i stop spraying
    President:
  • Simpson Master
  • 1,383 Answers
This is an indication that the unloader not working properly. When you release the trigger the unloader senses the increase in pressure and bypasses the water into the water inlet. When the unloader is not working and you release the trigger, the water pressure builds quickly and overcomes the power of the engine shutting it down. Here is the manual for your machine, http://www.pressurewashersdirect.com/manuals/Simpson_WaterBlaster%20manual_2.pdf
and some information about troubleshooting from the manual.
"Not Unloading. Leak in Gunvalve or Hose. Repair gun leak . Replace leaking or broken hoses. Debris or wear in Check Valve. Remove Check Valve parts and clean. Check O-Ring. Reface with emery cloth, or replace checkvalve. Damaged Piston U-Cup. Rebuild Unloader Valve (Service Center)."
Usually when the unloader fails the pressure regulator will most likely need to be replaced as the unloader is usually incorporated within. For now try lowering the pressure some and just tie the trigger open untill you can service. Good luck.
Posted on Jul 17, 2010
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Husky power washer does not spray cleaner just water.
Did you adjusted the sprayer? Only on low pressure will spray cleaner, if still does not spray, the problem is at the pump
Mar 10, 2013 | Garden
Can't get wash fluid to mix/spray out of Honda
I BELIEVE YOUR SPRAYERS ( JETS ) ON THE WINDSCREEN ARE BLOCKED. TO CONFIRM JUST PULL OFF THE HOSE LINE BY THE JETS AND ATTEMPT TO SPRAY.,IF THE WATER COMES OUT QUITE POWERED,THEN THE NOZZLES ARE THE FAULT. WHAT TO DO,IF YOU CAN REMOVE THEM AND DROP THEM IN A VINEGAR FOR FEW HOURS OR IF YOU DO NOT USE THE CAR FOR A NIGHT AND THE NEXT MORNING BLOW THROUGH WITH A PRESSURE AIR FROM THE SPRAYING JET SIDE TO THROW OUT ANY REMAINING. FIT THEM ON AND TRY AGAIN. ALWAYS IN THE MIXTURE OF YOUR WASHERS PUT SOME ALCOHOL.
Sep 02, 2012 | Cars & Trucks
Making a shuddering noise and cant seem to get full power
Make sure screen where hose attaches is clean for proper water flow to sprayer, make sure you have good flow from hose supplying water to sprayer. Turn water supply on, and hold handle down to spray, before turning on and see if it helps.
Jul 14, 2011 | Karcher Garden
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
We have a Moen 87315C kitchen faucet and it is dripping from the sprayer portion of the faucet, what's the problem?
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Apr 12, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Coleman 1600 pressure washer
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Apr 13, 2009 | Coleman Pressure Washer PW0881800
I have a dewalt 3750 pressure washer, when I pull the trigger on the spray wand the engine dies
I worked at a tool rental center while attending college and learned many tips and tricks about Dewalt and other brand pressure sprayers. Your machine probably has a 13 hp honda and has max pressure of about 3500 to 3700 psi. Most of the problems that customers had were engine related due to severe working conditions including totally wet engine /plug, wet air filter, and or other problems that were easy to remedy. We would set the pressure regulator to minimum pressure and explained to the customer how to increase the pressure as necessary but only after the engine was completely warmed-up to running temp to prevent engine stall. Your machine has a throttle lever between the tank and carb that should be set to max if you are going to set pressure at or neer max range. Most cleaning jobs do not need much pressure. Use lowest pressure to get the job done. Your engine developes around 13hp at about 3600rpm. If you want to maximize the life of you sprayer, then use your machine at about 70% of capacity or about 2000 to 2500 range that will allow you to run your engine slower increasing lifespan. Your sprayer is likely rated at 4 gallons per minute so make sure that the tip is that capacity. The tip has the size stamped which would show the fan degree and flow in gpm. The wrong tip, say a 3.5 gpm will strain the engine to point of stop because the smaller tip increases pressure. Most engine stall is due to high pressure setting on new machines. Lower pressure when warming-up machine and use max pressure rarely when necessary to max life. Please email for other information/questions or simple tests to determine faulty parts, good luck.
Jan 30, 2009 | Dewalt 3800 PSI Pressure Washer
Simpson WS4050V Water Shotgun 4000 Psi Cold Water Electric Start Gas Powered Pressure Washer W/ Vanguard Engine  Logo
875 people viewed this question
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
ray gallant
Are you a Simpson Garden Expert? Answer questions, earn points and help others
