Question about Nokia 3600 slide Cellular Phone
Whipe updating pc suite for Nokia 3600S the cable got disconnected once. The screen is now blank and tried to switch on but failed. Device given to Nokia Care centre. Their reply is not able to Switch On. Asked me to sent it to a repair centre for checking of motherboard. Kindlya advise.
  • 10,421 Answers
When i switch on my handset nokia 2730c it starts normal but suddenly its screen goes white(blank).
Try to reboot the phone without insert your Sim Card and Memory Card for 3-4 times.Even if there is no result you need to flash/update, so contact mobile tech or follow the instruction what I have given here.This is the best ever other than Updating via PC suit/Ovi suit.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 2730 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 17, 2011 | Nokia 2730 Cell Phone
How do i renewer my Nokia software
You can update your phone's software or reinstall it by following the steps below.
1.Download Nokia Software Updater from the following link.( http://europe.nokia.com/support/product-support/device-software-update/update-with-pc ).
2.Install it on your computer along with the PC Suite provided with your phone.
3.Connect your phone via USB Cable to the computer in the PC Suite mode.
4.Backup your personal data to the Memory Card or your PC using Nokia PC Suite.
4.Double click and open the Nokia Software Updater (Make sure that the broadband connection is active on your PC)
5.Your phone will be automatically identified by the Nokia Software Updater and will find the available software updates.If there are no new updates available for your phone you can reinstall the software.
6.Click on the start button to proceed.Please don't try to use or disconnect the phone until update is complete and phone is restarted.
7.Disconnect the USB Cable when the update is completed and phone is restarted.You can use the phone as usual.
Jun 21, 2011 | Cell Phones
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
My nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
I put a security code .. im truying to unlock my nokia E5 i get : code error .. what can i do ? i need to reset my security code please .. thank you a lot
Hi iba bob...
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
To flash you need
Try the follwing.... *check whether your phone or memory card memory full or not If memory is full clear some memory *Scan with a updated version of updated antivirus If problem persists you need to flash your handset
To flash you need
*A Computer
*PC suite of your handset
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option)
**Don't disconnect while updation process
Than you have a nice day...
Jan 31, 2011 | Nokia E5 Cell Phone
I cannot open messages from Inbox folder. Only able when I open it directly thru new message key shortcut shown on home page/screen once received. So I only get to read the message once and not able to...
Hi justinekaizz.......
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To flash you need
*A Computer
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Nokia Software updater by selecting this option)
Jan 31, 2011 | Nokia E63 Cell Phone
My nokia x 3 switches off eveytime, what can be wrong. shows a white screen then switches off
For this you need to flash your handset(if it is under warranty contact the service center)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank you
Don't Forget To Rate
Jan 25, 2011 | Nokia X3 Cell Phone
I would like to update Nokia n73 music edition software. May i know the procedure. Thanks in advance.
Hi
For updating your firmaware of Nokia N73
You need to Download The following tools
  1. Nokia Pc Suite
  2. Nokia Software Updater
or else Nokia Ovi Suite
But i Will say the methods using Nokia software Updater
  • Download Nokia pc suite from
http://www.softpedia.com/progDownload/Nokia-PC-Suite-Download-11999.html
  • And Nokia software updater From
http://www.softpedia.com/progDownload/Nokia-Software-Updater-Download-141287.html
Install Nokia pc suite then Nokia software updater
It will ask for your PC to restart
Continue ,then Select Nokia software updater .
Connect your phone
It will Find out the connected phone
Before Proceeding further: A Word of CAUTION:
  • Your phone will be useless when updating failed in the Middle of updating due to System Restarts or Internet Connectin Failure or Cable Disconnection
  • So consider in mind that
U Need
  • An UN interrupted internet connection
  • Do not disconnect the Data cable after full installation of new firmware
  • Computer shall not restart or shutdown while updating
(If any of this failed the phone cannot be recovered )
So method continues.....
after Nokia software updater finds your phone, it will check for new firmware avail for your phone or not ,
\if avail select download and install
Keep in mind the Above words of caution
An advice is that If You feel not good ,then better give it yor nearest Nokia Service centre ,they will install a new firmware for your phone
Hope this will Help You........
May 13, 2010 | Nokia N73 Music Edition Smartphone
Trying to update phone operating system but comes bake failed
Please tell me what steps and programs you are using. It should be something like this:
Install Latest version of Nokia PC Suite
Install Nokia Software updater
Connect your phone to computer via DKU-2 cable
once Nokia pc suite confirms that your hone is connected then run the Nokia software updater and it should do the rest.
If you need your data from the phone back it up 1st using the PC suite
Mar 14, 2009 | Nokia N73 Cellular Phone
Nokia 3600 slide Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
