Question about IBM Computers & Internet
I have problems trying to configure an IPDS Infoprint 6500 atached to an iSeries with R5V4 via TCP/IP. The status of the writer is pending.
  • 4,281 Answers
Make sure tcp ip settings are same in network range.
Subnet mask and gateway same in same network .
Also make sure driver installed and working fine.
Check firewall settings and open all tcp udp ports in firewall.
If no packet filters are active, nmap shows that ports 25, 80, 110 should 'open' on internet ip address. 443 ports need to open.
The below link helps you to configure it.
Click here.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 14, 2010
As400 LAN printer. queue has status of wrt but does nothing. can ping printer. have end/start writer, turned printer off/on, varied off/on. still will not print.
I'm assuming that you are using an IPDS device description. If so your Ethernet card need to have the defaults reset. There is an option to do this via the printers web interface.
Apr 23, 2015 | IBM Infoprint 6500 Matrix Printer
Tip
How to Check TCP/IP Configuraitons
The first step in the troubleshooting process is to check the TCP/IP settings. You can check it by using the IPCONFIG/All command on the command prompt. You will see the configuration results. If you see a blank configuration for a card this means then the card is not assigned any IP address. You can assign the IP address manually or via DHCP server. If you are using the DHCP server for assigning the IP addresses then you can use the following commands to get and release the IP address.
IPConfig/Release
IPConfig/Renew
IPConfig/All
If the computer is still unable to obtain an IP address, then there are several things that can causing this problem such as bad network cable or NIC card, DHCP server might have assigned all the IP addresses from its pool, mis-configured TCP/IP settings, incorrect user name and password. You can try to add a new well configured machine to the replace the malfunctioning machine to see if the new machine is working with its settings. Also see if the driver of the NIC is properly installed or not. In case of driver's problem go to the vendor's website and install a new exact driver for the NIC.
on Mar 25, 2010 | Computers & Internet
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
How to know the MAC address of my infoprint . In the config menu I got one but contains only 5 groups
If the printer is configured and has got a TCP/IP address, you can get the MAC mapping from any Windows PC in the same network like this:
Start -> Run Command -> enter "CMD" and press Enter -> type the command, PING ip.addr.of.printer (enter) and then ARP -a ip.addr.of.printer (enter).
If your network's IP addresses are centrally managed, ask your system administrator if it's possible to temporarily assign a fixed IP address for diagnostic purposes, then assign that address to the printer and do as described above.
Oct 30, 2009 | IBM Infoprint 1622 Laser Printer
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
Printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Feb 03, 2009 | IBM Infoprint 6500 Matrix Printer
Bar code
try changing the chacters per line, print out a config page and towards the bottom of this it will state the current settings
Jul 15, 2008 | IBM Infoprint 6500 Matrix Printer
Printer not working Error offline
I recently resolved the same problem by going into the Printer and Faxes under Control Panel. Look for the printer icon that shows in offline status. Right click 'Properties' and go to the Ports tab folder. Select the Port IP address in question and click on 'Configure Port' button. Click on the check box next to SNMP [SNMP status enabled] to remove the check mark and to disable the option. Click OK on the Configure Port window. Click Close on the properties window. Hope this helps.
Apr 17, 2008 | Office Equipment & Supplies
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
