Question about Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point
Too hot cause problems - Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point
  • 206 Answers
Overheating can be a problem so what you need to do is take a can of compressed aid and a small hand vacuum and vacuum out all of the dust
Posted on Jul 14, 2010
1998 isuzu missing alittle bit. Running hot. Radiator replaced. What is my problem
missing a little and running hot are indicators that you could have a head gasket problem. have it tested for a bad head gasket. the missing could be caused by coolant leaking into the cylinder causing a misfire, because of a bad head gasket. running hot is another indication of head gasket. if the rad cooling fan working properly. I think these have what is called a clutch fan which means, when engine is cold the fan turns slower than it does when its warm. if its turning slow when warmed up like when its cold it could be the fan causing the hot running.
Sep 28, 2015 | Isuzu Cars & Trucks
Crank sensor
Hot starting problems are usually fuel related. When a hot engine is shut off, the temperature of the engine and everything on it continues to rise for awhile as the engine undergoes a period of "heat soak." This can cause fuel to boil inside the carburetor bowl, fuel lines and fuel filter. When you attempt to restart the engine, "vapor lock" obstructs the flow of fuel and the engine doesn't want to start.
This is much less of a problem on fuel injected engines because the fuel is usually under much higher pressure inside the injectors and fuel line. Even so, a fuel line routed near an exhaust manifold or a fuel rail that's exposed to a lot of heat may still suffer the same kind of problems.
Heat soak problems such as these can sometimes be cured by wrapping insulation around affected fuel lines, and/or installing an insulating spacer or heat shield under the carburetor.
A Seasonal Problem Hard hard starting tends to be a seasonal problem, but may be worse in the early months of spring when refiners are switching fuel blends. Gasoline refiners produce fuel with a slightly lower volatility rating (called "Reed vapor pressure") during hot summer months because lower volatility fuel is less likely to boil and cause hot starting problems. During the winter, they switch to a higher volatility fuel because it makes cold starting easier. But if you still have "winter" grade fuel in your tank when warm spring weather arrives, you may experience some hot starting problems. The problem will go away, however, as soon as the refiners in your area switch to their summer grade fuel.
Other Causes Hot starting problems can also be caused by cooling problems that allow your engine to run too hot (the pistons swell up and may scuff the cylinder walls), or excessive resistance in the starter motor that causes the engine to crank slowly. A starter "amp draw" test can be used to check the condition of your starter. Also, many starters have small "heat shields" to protect them from heat radiating from nearby exhaust pipes or manifolds. If the shield is missing, the starter may get too hot and bind up.
Oct 20, 2013 | 1995 Mercury Cougar
Briggs and stratton engine misfiring cylinder
have a tappet clearance check done when the engine is hot and you will probably find no valve clearance. The valve stem stretch when hot and hole the valves slightly open causing the problems you describe as well as making hot starting difficult.
Jul 08, 2013 | Boating
Whirlpool hot water heater puts out overly hot water
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 03, 2012 | Water Heaters
My 2001 GS300 runs fine until it gets hot and starts missing. I changed wires, plugs and coil packs. what could cause this????
only thing left that would cause that problem would be the ignition module cold runs fine gets hot and shorts out common problem. good luck
Mar 11, 2011 | 2001 Lexus GS
Electric shower hot and cold
it sounds like the flow is too low and causing the heat chamber to overheat ( or the heat sensor is faulty and thinks it is too hot) is the water too hot before it goes cold?
Mar 18, 2010 | Home
HOT AIR BLOWING INSIDE THE HOUSE
I know there are not that many sites--very few--that cover the informational guidance on the maintenance and technical difficulties of evaporative coolers, and so I feel compelled to share with you this very good, but rare, handyman site that does:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
As you'll see, the link above has a section dedicated to evaporative coolers.
As to your specific problem of your cooler's blowing hot air, yes, the humidity is listed as one of six (6) possible causes of this cooler problem. To find out whether the other five causes are applicable to your situation, here is the direct link to the diagnostic article on hot-blowing coolers:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Does_Not_Blow_Cool_Air.htm
You should be able to review this article, and, one by one, determine what causes listed therein are not affecting your cooler in order to ultimately end up with one remaining listed cause that is the likeliest cause of your cooler's failure to blow cool air into your house.
This should help.
Brad
Jul 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Mixed Water Fill Causes Issues with Water Pressure
You will have to be specific about what problem the pump is having. It seems to pump ok for everything else. Could the hot solenoid be shorting and sending electricity down the water to bother the pump? Solenoids are not real expensive, try a new one.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
When engine get hot it looses fire and shut down will restart once cool
Check electric fan on radiator if bad will cause this problem
Jun 29, 2008 | 1995 Ford Taurus
Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point Logo
87 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
