Question about Coleman 10' X 10' Sundome Tent 9160K101
How to close a pop up, plantation 1988? and we need a new key for the main door where do I find a copy for the main door?
How do you change the rear light bulbs 1988 2 door hatchback tercel
Open up the trunk, and look for any screws that would link to the tail light light, remove them, then the tail light assembly should pop off. from their remove the bulbs and install new ones, you need to know the size, check modifiedlife.com for the correct light bulb sizes.
Jun 08, 2011 | 1988 Toyota Tercel 2 Door
Plantation shutters over sliding glass doors swing loose on the bottom.
plantation shutters is the best choice for cover glass window and also useful for security purpose.As per my suggestion allstar solar screens is the one of the best choice to plant the shutters.And plantation roller shade, pull down shades, zipper track shades & patio shades too. you can visit us at http://www.allstarsolarscreens.com/shutters.php
Mar 05, 2011 | Vacuums
The problem I am having is with the door locks, they do lock how they are supposed to it is just that when you go to unlock it the key you turn it to unlock it and it doesnt unlock do you know how i can...
There is a little plastic tab that helps to unlock the rod. If the plastic tab is broken, it won't unlock the door/rod. The best suggestion is to look on craigslist or hit your local junkyard and see if the plastic tabs are intact on one of the vehicle. You can use the models from 1986-1994.
Otherwise, you can lock the door before you close it, hold the handle up. Then, when you need to unlock, you will have to unlock with the key, the back hatch, crawl in and unlock the driver's side lock to pop all the rest.
Dec 25, 2010 | 1988 Nissan Pathfinder
Sc541 ricoh 1060
Verify the fusing unit contacts,thermistors and thermalfuses,heater lamps continuity.If is OK enter in the service mode:press yellow key -1-0-7 and press and hold 4 seconds the C red key.When appaire to the touch pannel service menu or copy sp press the windows,open the front door,close the copier machine on the main button and wait 10 seconds.Press ON the main switch close the front door and make a copy.If anywhere is replaced the heaters lamp,check the contact in the back side Orange wire to Orange wire,and the Red wire to Red wire contacts.
Dec 02, 2010 | Ricoh Aficio 1035 Copier
Key will not turn to unlock door
did you try the other door if still no you may need a new key. if just the one door it will need a new tumbler
Apr 22, 2010 | 1988 Dodge Dakota
DRIVERS DOOR WILL NOT OPEN, WHEN OPENED FROM INSIDE WILL NOT CATC
I have this on a Passat 1998 model and it's frustrating, im at the point where all 4 doors wont unlock and the 2 front ones work with the key but need to be closed with the key again.The boot opens and closes with the remote.I removed and cleaned all four door barrels when they opened intermitently and under the passenger side footwell is the ecu for the windows&alarm which i removed and cleaned as well as soldered 2 dry joints.If i activate the fob i hear the relay in the ecu click and double click to lock and the boot lock works which indicates the electrics are ok.Doing a google there are 1000sssds of queries with passat/vw door lock problems and the main cause is dry solder joints in the door lock mechanisms in the door.I found out from the main dealer when replacing my bootlock(the old one was damaged in a theft attempt) that a new modified part was available and the same for door locks????leading me to believe this is a widespread problem.The only thing is to remove the door parts and inspect the catch and circut board for dry joints.This link may help you. http://forums.vwvortex.com/zerothread?id=1542461 copy and paste this into your browser or google the website if you dont know how.
Feb 10, 2010 | 2006 Volkswagen Passat
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
I just replaced the wiring harness on a 1988 mazda rx7 and now the car will not star. the steering wheel lock had to be broken on the car to move it so the anti theft system that came with the car thinks...
you need the original black plastic key that came with the car lock all doors and make sure anything that opens is closed. then unlock the car on the driver door with the key. If you lost the key look in the owners manual hopefully the code on the key is written in there and then go get a new key made at a mazda dealer. Hopefully this helps. Maybe you can help me i need to replace my wiring harness and i dont know where the clear 4 prong plug is located under the dash on the main harness. i already unplugged the two orange ones and the two from the computer i just cant find the lear 4 prong one.
Jun 13, 2009 | 1988 Mazda RX-7
Key for 88 Bronco door, what is best way to acquire key?
a new set of door lock cylinders from lmc, comes with keys, only like twelve bucks
Mar 13, 2009 | 1988 Ford Bronco
Coleman 10' X 10' Sundome Tent 9160K101 Logo
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
