Question about Exercise & Fitness
TUNTURI TREADMILL THAT HAS E4 CODE AND ELEVATING PROBS
HI I HAVE GOT A TUNTURI TREADMILL THAT HAS ELEVATED UP AND WONT COME BACK DOWN IT ALSO HAS A E4 CODE BUT WHEN ITS GETS UP TO SPEED IT OVERIDES THE E4 CODE WHICH I CAN LIVE WITH BUT NOW IT IS STUCK IN INCLINE MODE WHICH IS TOO STEEP .PLEASE HELP I NEED TO HAVE A OPERATION AND NEED TO LOSE WEIGHT QUICK LORAINE
SOURCE: The riser on my Tunturi T20 is stuck on maximum
Phil, I have had the same problem today.
did you solved the problem already?
Posted on Jan 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
maxtreadmill
  • 832 Answers
SOURCE: My Tunturi Treadmill ramp is stuck in the top
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Posted on Jun 14, 2010
  • 218 Answers
SOURCE: my treadmill does not incline
incline motor has failed and needs replaced
Posted on Aug 14, 2010
New balance treadmill 1500 error 3
the elevating motor has gone up past it's limit sensor
you must manually spin down the elevator motor then plug the treadmill back in to fix it
Mar 15, 2018 | New Balance Exercise & Fitness
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
http://electro-medical.blogspot.com/
Feb 23, 2016 | Tunturi Exercise & Fitness
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    My cardiozone supersport HR club II started elevating by itself to highest level then stopped running but stay elevated. Could not get it to return to lowest level, just stuck there. I got an E7 code on...
    Sounds like the motor control board went wacko.....ran the incline motor all the way up and shut down the treadmill motor for no reason....sounds like a control board problem...
    heatman101
    Dec 15, 2010 | Sport & Outdoor - Others
    Treadmill wont work
    Error Code: Grade potentiometer out of range (PO error)
    Meaning: error detected in the elevation system you need to recalibrate the elevation potentiometer You can find a qualified technician or send me an email to cardiotech_me@hotmail.com to explain the steps.
    Jul 05, 2010 | Landice L 7 Club Cardio Trainer Treadmill
    I have a Tunturi j770 treadmill with error code E1. What does this mean please?
    Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
    May 17, 2010 | Exercise & Fitness
    Exercise & Fitness Logo
    97 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
