Question about Canon EOS 400D / Rebel XTi Digital Camera
I have had my Canon EOS for 2 years. In the past week, I've been having trouble taking pictures. It seems to work fine if I point the camera down but it won't always work when taking a level picture and won't work at all when I point the camera up.
    Brigadier General:
  • 11,967 Answers
Sounds like a mirror problem.
Posted on Jul 14, 2010
I have a Canon Rebel XT. After taking a picture, the viewer shows the shot upside down and when I down load to my computer they come in all upside or sideways. Just started doing this and I've had
The EOS cameras have some sort of sensor built in to tell the camera which way the shot should be orientated on screen and when they are transferred to the computer.
It sounds like the sensor is jammed or broken and sensing (for some reason) that the camera is upside down when the shot is taken.
If you don't want to pay to have it repaired you can use a program to rotate them or turn of the image rotate option in the menu. I believe this ignores the sensor information.
Jun 24, 2012 | Canon Cameras
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Have Canon EOS Rebel Xsi Digital. Burning smell and flash busy.
Are you trying to use the flash when you are having the problem? Were you taking a lot of pictures with flash when the problem started? Rapid pictures with flash can melt the flash and capacitors in the camera. Also, a single drop of water rolling around inside the camera in the right place can do things like that. You can try taking pictures in bright sunlight so the camera will not try to use the flash and see if it will work normally, If it does than something is probably fried in the flash system. Bad thing is that if you smelled smoke something is most likely already fried and will have to be repaired by canon. Canons quality has been going down hill for several years now and they have a lot of quality problems. If the camera has been used very little, has never been abused, dropped or wet and not far out of warranty, try using google to see if this is a common problem and call canon and try to get them to repair it for free. If all else fails threaten to replace it with a Nikon assume pay to have barely used camera fixed.
Sep 29, 2009 | Canon EOS Rebel XSi Digital Camera
Canon EOS 300D will not take photo's
do you get black frames or no record at all???
Seems like your sensor went dead on you....
Jul 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Battery meter
Give a cleaning to the contacts of the camera in the Battery chamber.
Look for the contact plate in the battery cover.
Look in the film pressure plate in the back door,and check its position or look for any dirt between them.
Then you have to check the drive motor.
Oct 11, 2007 | Canon EOS Rebel G 35mm SLR Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
