Question about Samsung 26 Cu. Ft. Side-by-Side Refrigerator, RS267LA
I have a Samsung side by side model RS267LASH refrigerator. The fan on the refrigerator side was making a weird noise for a few days and suddenly it stopped cooling. The freezer side stays cold. I removed the cover on the inside and discoverd the coils were a solid block of ice. I am in the process of defrosting. What can I do to keep this from happening again, and is it covered under waranty? It is just over three years old.
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 531 Answers
SOURCE: Refrigerator warm and defrost heat sheath and coil frozen solid
check see if you have frost build up in freezer could be the heater or defrost thermostart or timer board call service
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Posted on May 22, 2009
RS267lash samsung refrig. display panel fridge
Sounds like the fan unit is faouling with ice. The solution is to remove the whole of the contents and then the units inside at the rear. Defrost same and re assemble. Its not that hard if you remove the light difuser first and the two screws. Mark the difuser for top. Then ease out the unit and remove after taking out the electrical connections. They fit only one way. The lower unit has four screws. Two under covers. Easy to unclip. The ice seal may mean that it is not that easy to remove. Defrost both the units with a hairdryer or similar and clear insulation from the fan drain. Re assemble when clear and as dry as you can. The problem will come back so be aware that you have to repeat the procedure when the fan gives signs of fouling. Paul.
Jul 11, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
Model #RS267LASH fridge is not cooling but freezer side is. What could be the problem with this Samsung? Thanks,
If your RS267LASH refridgerator is not cooling it is because it is not defrosting. In order to fix it they will have to take it into the shop to cut into the copper wiring, remove the freon and change out the probe inside. The parts and labor are covered under warranty for 5 years. This was the last thing done to mine after changing out the board, a fan, and a thermocouple.
Jul 12, 2009 | Samsung Refrigerators
The refrigerator portion has quit cooling.
I have the same problem and have found that if you take the panel off inside the refrigerator and with a blow dryer defrost it. It should work for a few weeks. I have been doing this once a month since March and I hope to found out how to fix it also.
May 17, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
May 12, 2009 | Samsung Refrigerators
Loud noise from Fan and compressor
i have the same problem with mine. I took the back cover off at the bottom and the fan was going. get a scredriver and barely touch the center of the fan while it is on and if it stops making the noise then it is the fan motor. The bearings are getting ready to go out and it needs to be replaced.
Mar 22, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Hi Adshegern,
Good luck
Mar 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud noise from the freezer side
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator fan running but not cooling, making loud noise
Shayon, what is the model number? Maybe I can help you out. Scott
Jun 02, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
