Question about Janome 1600P-DB Mechanical Sewing Machine
I have a Janome machine do not know wihich model. just a regular sewing machine with a variety of stitches. The top thread keeps breaking after a few seconds of sewing. what should I do. i have lost the manual
    New Friend:
  • 194 Answers
This is a classic sympton of the needle in backwards, try turning it around and see if it works. Maybe its your lucky day!
Good Luck
Posted on Sep 02, 2010
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
Having difficulty with free motion machine embroidery on my Janome Mystyle 16, top thread keeps breaking. What can I do to stop the thread from breaking? Plus the stitching is very erratic,any ideas?
1. Set up for regular sewing (not embroidery).
2. Adjust the tension of the bobbin and the top thread so that you have a nice straight stitch.
3. Check your thread quality. Is it fuzzy or have small trails sticking out. No Walmart thread allowed. Only top notch embroidery thread allowed.
4. When you've been successful with the thread and tension go ahead and set up for free arm.
5. Sew free arm but remember machine has to keep up with you. If you go too fast you will be pulling the thread and probably will break the thread.
6. Your erratic stitch is caused by the speed at which you are moving the hoop. Going fast; then slow is going to make a long stitch and then a short stitch, etc.
Apr 03, 2015 | Janome Sewing Machines
Janome travel mate bobbin assembly
there could be something wrong with the hook and the hook race
or there could be a timing problem with the machine.
check to make sure the top thread doesn't come off the thread take
up lever when sewing
make sure the bobbin is turned the right way also.
Dec 05, 2012 | Janome Sewing Machines
I bought this machine a week or so ago. (Janome 4900 Memory Craft) I feel like I must fight to keep it going. The thread breaks constantly; I have changed at least three needles. The overlocking stich...
I have a Janome 6500 and I initially had several problems and took mine back 3 time in the first year. I was disappointed with how easy it was to jam up the bobbin race and dislodge the bobbin holder out of its correct position, resulting in damaging the case (by the needle striking it). Because the bobbin case is held by magnets, I would jam it constantly by loading up the machine with thick seams, the bobbin case would dislodge, the needle would strike it and bam, out of action again. I've replaced the case twice so far and if I damage it, sometimes I can file down the plastic burring with a nail file to keep it going. The Janome lady pointed out to me that sewing jeans hems is a lot to expect and I should not stitch over the seam intersections with my machine without using a "jean-thingummy" plastic tool to help the feed dogs manage the extra thickness and get grip. Changing needles is something that you will have to adjust to, modern machines require a new needle every 4-6 sewing hours or each new project. I understand that the old Singers were not like this at all. Sorry, fact of life, you'll need to change them regularly. If you form stitches slowly using the flywheel and can hear a popping sound, your needle is blunt, change it. Also if your top thread is breaking, just check that you've got the thread arm aerial up so that the thread can run freely. Use good quality thread, clean out the tension discs regularly and double check that the bobbin is correctly under tension and that the red arrow and dots showing the bobbin case are aligned up correctly. Also, when winding bobbins, keep and eye on the thread filling and make sure it fills top and bottom, not just the middle area, give it a nudge with your finger tip as it fills to do this. And keep a little gentle tension on the thread reel so the thread feeds off at a constant tension onto the bobbin. If you check some other sewing machine forums you'll find that the above issues are not uncommon with these machines. I guess you have to weigh up if the other stitch features are worth it and maybe keep a heavy duty vintage machine for the tough work, I did.
Feb 28, 2011 | Janome Memory Craft 4900QC Mechanical...
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
80 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
