Question about Garden
Electric start works fine - but it putt put pputs until it dies. i just brought it from the repair shop - busted belt - and they competely serviced it. Brand new gasoline - plenty of oil
  • texcyn Jul 16, 2010
    can you tell me how I take out the fuel tank? I love challenge but yikes - sounds complicated. I went to ehow but they suggest syphoning?? Yuk
    President:
  • 2,047 Answers
In the process of servicing they might have skipped checking the fuel pump and the nozzle that supplies gasoline. If this contains some dirt then it would not supply needed gasoline for the machine to work well. This could also be caused by an electrical fault from the plugs or electrical coil. Unless you have the technical know how i would ecommend you send it back to the repair shop. But if you could send specific details of make and model i could give you detailed steps to attempt fixing the machine. Hope this is helpful?
Posted on Jul 14, 2010
  • 2 more comments
  • texcyn Jul 14, 2010
    thanks - waas trying to avoid taking it back to that repair shop that took 3.5 wks to fix. This eve i wil get the extra info and send to you tomorrow - any help to fix myself is greatly apprecaited.
    Cynthia
    Hi - here's a new wrinkle. So I tried the lawnmower last night and it started and ran like a charm for about 6 mintues - then it started puttering again and then a huge black cloud of smoke came out of the left side.
  • Purchased from Home depot 15 mos ago.
  • MFG Brand Name : Toro
  • MFG Model # : 20334
  • MFG Part # : 20334
    just making sure you got my extra info
  • Rockme
    Rockme Jul 16, 2010
    Hello there yes i did... this indicates there is some dirt in the system...it ran well for about 6 minutes cos the dirt in the system has settled down but once you start running it the dirt comes up again and disrupts the system. Try this little trick leave the machine idle for about 24 hours take out the fuel tank empty the fuel into a gallon, wash the tank and put in fresh fuel and run the system..let me know what happens after that. Hoping to hear something positive.
    2001 Nissan start jerking on hway, died, putt putted home. Now starts dies out and backfires.
    Make sure timing belt ( if equipped has not jumped/skipped teeth ). If ok suspect system running too lean ( not enough fuel ). You need to check for proper fuel pressure. Possible restricted fuel filter or defective fuel pump. Also there are a few sensors the vehicle relies on for fuel delivery that may have to be tested as well.
    Jul 05, 2015 | Nissan Cars & Trucks
    Fan belt got busted need replacement
    We can put the pieces of a broken belt fasten with wire series, can be make do without paper clip wire, but as soon as possible to the the nearest repair shop for repair.more question go this web
    Mar 29, 2013 | Cars & Trucks
    Cuts out at 2500 rpms and dies on idle
    2 possible reasons
    1--- failed cat converter blocking the exhaust
    2---EVAP system not venting the fuel tank properly
    run the fault codes and have an exhaust shop check the at converter
    Nov 22, 2017 | 1997 Nissan Pickup
    My Honda CRF230 won't start. The battery is charged, I'm sure. We tried compression starting it and each time it works but within 3 seconds it makes a putt-putt sound and shakes a little before...
    Definitely get it jetted my CRF 230 did the same thing as that then I took it to the dealer and they put a new main jet pilot jet and the choke jet and took it back home and it starts fine even in -5 conditions first go I only have the choke on half
    Aug 07, 2011 | 2003 Honda CRF 230 F
    My timing belt and water pump for Honda Accord 1990 was replaced and used the car for 2- 3 weeks. After driving about 15 minutes, entering the freeway, my car slowed down but the engine still running....
    If you have never changed that distributor on your 1990 Accord, I would suspect it. Check for spark while cranking. The sensors inside the distributor would usually heat up, after 15-20 minutes of running, and would then die out, until the car is cooled off for a while. Look into that distributor.
    Oct 07, 2010 | 1990 Honda Accord
    2002 Rodeo starts revs up to about 3rpm then slows to about 1rpm then lopes then stops. During this process the check engine light blinks on and off. I used this service a month or so ago. The...
    if your check engine light is blinking, take it to a diagnostic repair shop as soon as possible. it usually means that there is something seriously wrong with it
    Mar 09, 2010 | 2002 Isuzu Rodeo
    I have an Amana NED7200TW Electric Dryer that was working fine before I moved it from my brothers house to mine. Now the heating element is not heating up. Everything else is working fine. Any suggestions
    You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
    http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
    Nov 17, 2009 | Amana NED7200TW Electric Dryer
    1999 chevrolet venture
    check the fuse box a lot of problem right there
    Jul 09, 2008 | 1999 Chevrolet Venture
    Screen flickers upon power up
    Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
    Cheers!
    IrishDruid
    Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    External HDD won't start up
    putt the actual hdd in master and the 1 ur having problem with in slave mode boot windows go 2 controle panel administartive tools and device manager or manegment somthink like that and in the diagnostik box take the last option frome the second 1.u must see ur seond hdd that u put on slave..format it...after that putt it alone and boot frome windows xp and install ur windows this will work
    Jan 08, 2008 | Computers & Internet
    Garden Logo
    19 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
