Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Bravia kdl-40s4100 has no sound, no picture. Checked the line fuse to the HV power supply and it checked good. PS problem? Where can I find a replacement circuit board or would I be better off replacing the TV?
    Problem Solver:
  • 17 Answers
You have a power supply problem,please go to ebay.com and search for my store,texas-tvparts.
i have that power supply and more tv parts in stock and i can guide you on the repairs,thanks a lot!!!
Posted on Aug 13, 2010
  • Sony Master
  • 8,457 Answers
The 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards are dead,must be replaced.These 2 long LCD inverter boards help the LCD screen to have a backlight to have a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Posted on Jul 14, 2010
  • Chi Chu Jul 14, 2010
    Tries unplug tv about an hour and replug it back in, might get the tv to reset it self and work.
  • 11,361 Answers
Since you have no picture or sound, then more likely to be power supply or main board problem, so check the power supply output voltages first, shorted out backlight inverter board will also cause the power supply to shutdown also, so try disconnecting the inverter from the power supply board to see if the power supply will start back up and at least get the sound back.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 15, 2010
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Lost the screws that attached to the TV stand for
Required screw part number is as follows as per service manual of Sony KDL-40S4100 model..
7-682-973-49 SCREW, +PSW 5X16
and it is available in Part Store, click the link and I think TV needs 4 screws or so.
Thanks.
Posted on Sep 15, 2009
Testimonial: "Very useful information. I will go ahead and purchase the screws. Thank You."
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
SOURCE: Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
Posted on Dec 24, 2010
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
Sep 06, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia 5 blinks
Hi Tradeboyle,
Please search 'Sony Bravia KDL-40S4100 40 in five blinks' on google and you will get several videos containing the solution of your problem.
Good luck.
May 12, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a sony bravia model # kdl-40s4100 40 in that wont power up what are the problems that could cause this?
If you have the led light on, then you need to replace the mainboard.
If no led light then replace the powerboard.
Jun 06, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
No Picture on TV when Power is on
This seet should provide some diagnostic help. The standby light should be blinking a repeated count with a pause. Post that count here. Also, is there sound?
The above info will indicate the problem circuit which will then suggest the remedy.
Thanks,
Dan
Jan 19, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
947 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
