Question about AT&T EP5632 Phone
AT&T EP5632 phone won't register or find base.
I have an AT&T EP5632 phone recently bought (within 2 months) and now they're not supporting it. The problem I'm having is with the handset that came with it. It made one call before a message started appearing "system busy." This went on for a few days, so I set the handset to it's default settings. Then, it never could find the base. It was always "searching for base." After no luck with AT&T, and following all the trouble shooting in the user manual to a "T", I reluctantly deregistered the phone to try and reregister it. Now it won't register. I've tried all that I know to do, and all I've found to try. Can you help?
I had the same problem happen to me as well and I took the batteries out of all handsets, and unplugged the base for a few minutes. Then plugged in the base, reinstalled the batteries and it registered all handsets lickety-split. Hope this helps you.
Posted on Feb 11, 2011
  • Susan Zazas Feb 04, 2013
    Did not work for me. My cordless handsets both still say, "Searching for Base".
    Didn't work for me. Any other ideas? (I left them all unplugged for at least 5 minutes.)
Did the exact thing mentioned above. Batteries out of all phones, unplug base for a few minutes. Plug everything back in. Base found . Problem solved.
Posted on Mar 24, 2011
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
HandsetS #2 and #3 work properly. Handset #1 has a display screen with correct datet and time -- but no dial tone, How can I fix this?
This sounds like Handset #1 has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go.
Nov 26, 2015 | Uniden DECT 6.0 Cordless Telephone...
Having problem connecting: handset out of range
This sounds like the handset has lost its "registration" with
press [SELECT]
a "Handset #" and be good to go...
Oct 05, 2015 | Uniden DECT 6.0 Cordless Phone
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
CIT310 - registration problems with the base
use the pager button, keep it pressed for about 15 seconds, and then use the register option from the phone, handset will pick up the signal. You may have to do this multiple times.
May 27, 2009 | Linksys CIT310 IP Wireless Phone
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Mar 11, 2008 | Lands Phones
Model28112 series cordless phone multi phones 4 total
This does not sound good. If you have one working phone and you have swapped batteries around and still the same single phone works.... you know it's not the base unit, charger stands, power supplies or batteries. You have eliminated everything but the phone itself. Unfortunatley these low end cordless phones cannot be expected to last. 6 months is pretty bad but I'm not surprized. These sell for $30 each new and I bet a replacement battery is $20.
Jul 01, 2007 | GE 28112 Trio Cordless Phone
Open Questions:
Static and short range on handsets when base unit is cold This is a strange one: the base unit of my cordless phone (AT&T EP5632) has become very temperature sensitive in the last few months. The phone is about 3 years old, and when the weather is warm, i.e., room temperatures over about 75 degrees F, it works ok, but when the weather is cold, i.e., room temperature below 70, there is a lot of static on the line when using either handset. This static slowly disappears if the phone is used for a few minutes and after a 5-10 minute phone call, the line is clear and the range is good. The speakerphone on the base unit works fine all the time (perfectly clear), so it is not a problem with the line. The Bluetooth connection works pretty well too, though it does have a little of the same static sounds, just not so much as to be unusable like the handsets are in the morning. The handsets also have been suffering from a significantly reduced range over the last few months: they used to work across the yard in another building, but now they need to be 10 feet away to get a dial tone and at night they loose the connection to the base unit when on the charger upstairs. I have tried moving the base to another room, but this did not help, and in fact this seemed to make it worse for a while because the unit cooled off while it was unplugged. Any ideas how to fix this would be welcome. Since it's out of warranty and I'd even be willing to take it apart and resolder things if needed, but I can't seem to find any tech literature on the unit. Thanks so much for any help you can provide!
Feb 28, 2017 | AT&T EP5632 Phone
See all AT&T EP5632 Phone Questions
AT&T EP5632 Phone Logo
1,233 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
