If the choke cover is free,then how much is the handle that is broken?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I recommend that you do not remove the door or hinges to do the job because if it's not aligned exactly, you can have microwave leakage.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave Oven replacing plastic film on inside of door
FSP stands for "Factory Service Parts" which I believe was originally terminology from Amana, which now (along with several other brands such as Electrolux, Frigidaire, Jenn-Air, Kitchen Aid, Litton, Roper, and Whirlpool) is now under the Maytag umbrella.
Confusing, eh??
Hopefully the new one will have adhesive included. If not, then you'll have two sheets to use to get it right.
In that case, I'd probably recommend the spray-on type adhesive you can find at hardware stores or big box stores such as Wal-Mart, Home Depot, Lowe's etc. It will probably be made by 3M.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: replace door handle on mco153uq
Normally You have to
and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
In some cases, you then
have to gently rotate the handle to unlock it.
You can order parts here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Normally
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
SOURCE: Replacing a whirlpool microwave door handle! got
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
The handle on my microwave door broke and now where it is attached has cracked the mounting around the door. Can you help me?
What is the price for a new handle?
