Question about Universal Kreepy Krauly In-Ground Pool Cleaner
It wont stay in the deep end - Universal Kreepy Krauly In-Ground Pool Cleaner
  • 640 Answers
If these automatic pool cleaners are staying on one end of the pool, there are a couple things that could be causing it. First, check the return line water flow and redirect as necessary with an eyeball diverter. Also, make sure that the hose is long enought to reach each end of the pool. Also check the hose balance.
Posted on Jul 28, 2010
Pitco fryer pilot light wont stay lite
The thermocouple is bad or the pilot light is not adjusted to heat the thermocouple to the point where the safety shut off stays on.
Jul 09, 2014 | Pitco Frialator 35CS Deep Fryer
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
Deep end only
adjust floating handle
Jun 03, 2013 | Aqua Vac Tiger Shark
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Barrauda quatro stays in deep end
I have a G4 and have to adjust the intake valves to reduce flow from the skimmers so it increases suction from the vacuum. That usually will bring it up from the seep end. If it worked before and not now, inspect your hose for leaks/rips/tears.
Aug 23, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Pilot light
my deep fryer pilot light lights but wont stay on!
Mar 14, 2008 | Vulcan EF3 Deep Fryer
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
230 people viewed this question
Top Universal Pool & Spa Experts
Marvin
Marvin
pawnpower
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
