I have a DELL MFP 3115CN and it faxed fine when i First Installed it. The Line rings but the fax doesnt pick up. Is there a way to fix the fax and test it??
  • 1 more comment
  • yan dikshteyn Jul 15, 2010
    Set all the rings to auto ans and 5 sec, couldnt find the default reset settings. I even disabled ecm correction mode in service mode. The line fax dials it send a fax signal and then it sounds like it faxing but it drops and dispays job failure. Thanks
    I get a dial tone, I tried a different line and the result are the same, the line is fine it gets a tone. The fax starts dials and gets a fax sigbal but it doesnt complete. I need some help from someone that knows this machine Dell 3115cn.
    Thanks
    awesome thanks ill tyr it
  • 2,272 Answers
Are you able to receive fax? If yes then Try this. go to printer settings then go to fax settings.In that select the option.Set as default.Once this option is selected all the settings will be set as per required.Then check out. For complete user manual of your Dell MFP please click on the link below http://www.scribd.com/doc/17927895/Dell-Multifunction-Color-Laser-Printer-3115cn-Users-Guide-Manual --------- For default fax settings check out page number 34. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 15, 2010
    President:
  • 1,561 Answers
Check to see if the fax machine is properly connected to the telephone line and that there is a dial tone. This may be the cause of not being able to receive or send any faxes. Find out if the phone is giving you a dial tone. If not, call the phone company to send out a technician.
Examine the plug or chord to make sure that the fax machine is plugged in correctly. Test the fax machine by trying to send a test fax. If that does not work, plug the fax machine into another outlet. If you use a surge protector, make sure that it is on. If not, call the phone company to send out a technician.
Take care.
  • Sulaimon Jimoh Olayemi Jul 15, 2010
    Turn on the machine and pick up its telephone. If you don't hear a dial
    tone, check your phone cable to make sure it's secure. Then turn to the
    LCD screen and start programming your options. Since all machines are
    different, see the instructions in the owner's manual.
    Place your document in the fax machine. There should be an icon on the
    machine telling you if it goes face up or face down. Then dial the
    number and wait for confirmation.
    Take care.
  • 4,281 Answers
First make sure autoanswer is enable in fax.
For that press menu button of fax and enter in fax settings.
Then enable Auto answer then save settings then check.
if still not work then reset all settings to defaults then again enable auto answer and restart fax.
Let me know if you need further assistance.
thanks for using FixYa.
Posted on Jul 14, 2010
  • yan dikshteyn Jul 14, 2010
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
I can not receive faxes on my Dell MFP 1125
Hi, I have Dell 1125 All-in-One Laser Printer. I can send faxes by going to fax option and dialing the number.
How can I set it up to receive faxes? keep in mind that I have only one phone line which I use for both phone and fax.
How can I set the ringers in a way that for example at 4th ring goes to answering machine and at 6th ring goes to fax?
I really appreciate it.
Need help fast :)
Mary
Aug 03, 2010 | Dell 1125 All-In-One Laser Printer
I have a dell mfp 3115cn copier, fax, scanner. Th...
the fault is a mark on the glass over which the paper passes when being copied. it is the rectangular glass that is probably only 1cm wide but the full A4 length across the screen. Clean the mark off this thoroughly and voila, fixed.
Bristolprinters Ltd - with compliments!
May 21, 2010 | Office Equipment & Supplies
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Jan 26, 2010 | HP Office Equipment & Supplies
OKI B2540 MFP .... Just in the process of setting it up. I have one problem: I have one telepone line that rings once for most incoming calls but for faxing purposes I have a second number on the same line...
You need to get an auto switch box such as the Command Communications Comswitch 5500 it was what is called distinctive ring and that if the function you need. You can plug in your phone, fax machine, answering machine, etc. You can get them from Office Depot, Office Max, Staples and such.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | OKI B2540 MFP Printer
We have a HP colour laser jet CM2320nf MFP and when we try and send a fax it comes up with error report Comm Error 345. Please explain
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Cheers
Soulvisitor
Nov 27, 2009 | HP Laserjet CM2320nf All-In-One Color...
Xerox PE120i not answering - phone line tested ok and fax 'rings' but doesn't 'pick up'. Set to answer after one ring. Anything obvious to check please?
make sure its on the line in plug not line out. test a fax out to you other phone (doesnt have to be a fax)to see if it rings
Oct 15, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Fax Transmission fail from Dell Laserjet 1815dn
what do we do if our dell fax machine lazer mfp 1825 doesnt send or recieve faxes?
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
579 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
