Question about Olevia LT37HVS 37 in. LCD HDTV
HD screen Hi i have olevia lt37hvs more then 1 year now(no problems in this time) But from like 2 days ago i have problem with Hd channels. A am using HD antenna, sometimes works an fiew hours and next time 1 min. I am getting loud noise and screen its mix of color pixels. After that i need to turn off tv to fixed. When i am using Normal channels, dvd, or computer i dont have this problem( Just HD channels). Plz help
  • Anonymous Mar 17, 2014
    the hd channels have alot of distortion, like flashing color pixels. the regular channels r ok. why?
    Genius:
  • Olevia Master
  • 1,689 Answers
You should verify that you are not just simply losing reception from a fault in the antenna.
If the signal is okay from the antenna, it is possible that the TV is having a failure in its tuner or IF sectons just to mention a starting point.
Jerry G.
Posted on Apr 20, 2008
My Comcast Proscan HD TV has a small screen on non HD channels.
I have 2 pro scans Comcast hd. On Comcast remote small button ( for me Its small circular button bottom right) HD ZOOM. (enter above it)
Aug 30, 2012 | Televison & Video
L have an olevia flat screen tv that turns off on its own whenever... what could it be?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Apr 04, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I'm new to the HD world...just purchased a LG 42LH40 a couple days ago...and have a couple questions to make sure my TV is operating right. 1) When watching an HD channel (CBS for instance) there is about...
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Jan 09, 2010 | LG 42LH40 LCD TV
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
Olevia 237t No Audio or Video on HD Channels
Try to connect the ROKU player to the television directly
Make sure that the internet connection to the player is from your router
Use your television remote to select the proper input to your television
Try this and check if it works.
It should work
Oct 23, 2009 | Olevia 237T 37 in. LCD TV
Olevia 37" Hd flat screen, picture does not fit screen. Sporting event scores are off the screen.
You need to check the aspect or screen size settings on the TV as well as your signal scorce IE: cable box, satelitte if they are HD?
Sep 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Jan 09, 2009 | Televison & Video
RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Feb 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Olevia LT37HVS 37 in. LCD HDTV Logo
171 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
