Question about Jenn-Air Kitchen Ranges
Jenn air downdraft range , oven not heating well
Jenn air downdraft range mod# JDS9860AAP
Oven temp not rising above 250 (and very slow at that). Humming noise from rear top right side.
fridgetech
  • 473 Answers
SOURCE: jenn-air manual
You can find everything you need and diagrams at http://www3.sears.com/.  Just type in the model #.  There is no repair manual that I know of.  If you need help solving a problem once you have seen the wiring diagram let me know.
Posted on Oct 13, 2007
SOURCE: will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Posted on Feb 13, 2008
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: how to cancel f9 code
JennAir F code 9
F9 Door lock safety circuit on power relay board sensed Replace power relay board
Posted on Nov 10, 2009
taran_2005
  • 10515 Answers
SOURCE: I have a Jenn Air S136 range/oven downdraft. The
Kindly provide few more details :-
1. when did you use it last time?
2. How old is the unit?
3. Is it completely dead or shuts off?
4. Do you have any error message on the screen?
5. Have you disconnected the power supply for 5 minutes and then turn it back.If not, try and see, if that helps.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn-air elecrtic oven JDS9860AAP is slow to heat up and will not come up to temp.
Either you have an open element a burnt terminal lead or a bad control try setting on broil only the element should glow in bake the bottom element should glow while the top cycles on/off based on your description of a humming noise I would suspect the relay on the control board
Feb 16, 2015 | Jenn-Air Kitchen Ranges
Oven doesn't heat up all the way on our Jenn-Air duel-fuel range
all repairs should be performed by an authorized service person. if your breakers were tripped there is a high voltage short or weak home breakers. when resetting the breakers make sure the dual breaker switches are in the on position. if the is ok check for the proper voltage is at the power outlet is correct.if it is ok unplug the range. be sure not to break the gas line. remove the rear panel check to see if the power cord power cord is secured to the power cord terminal.if the terminal is damaged do to the shortage at the terminal replace the terminal and power cord. when replacing the power cord and install the power cord restrain that usually comes with the.power cord.
Jun 02, 2017 | Jenn-Air JDS9860AAS Dual Fuel (Electric...
Jenn Air W256B error code F8
Hi, F8 on later model jenn-air ranges/wall ovens indicates an issue with the meat probe, usually the resepticle. The fault is sensing a temp. at the probe above 250. Unless you actually have the meat probe inserted into the recepticle and the oven has heated above 250, then it's not likely the meat probe itself. Hence why the recepticle is likely faulty or in need of inspection/adjustment. Here's how (this may or may not work...sometimes it does though). First unplug the range or shut off the power to it. **The probe is attached on the oven liner via a nut, however you,ll need to gain access to the outer side of the liner by removing the side panel if the recepticle needs to be replaced, but hold on.** You nay only have to loosen the nut and re-tighten it to insure the recepticle has a good "ground" to chassis. there is only one wire attached to the other side (you can't see it) because the probe converts temperature to resistance in the control, that is why this "ground" is essential and can cause "faults" if not secure/sufficient. At times that's all it takes to force an F8 code. Try this first, reset the power and see if it yields a successful remedy. Hope that helps, good luck Hope that helps, good luck
Oct 03, 2009 | Kitchen Ranges
I can't get the oven temp to set on my Jenn Aire eletric range
I was looking to see what kinds of problems the JES9860 electric slide in was having. I am not sure if this is your model, but if you go to the Jenn Air site, you can find your model, click on it, scroll to the bottom of the page and click on SPECS & LITERATURE, its to the right of "features". You should be able to Download the manual on the guide there and that shouldhelp you to set the temp correctly. If anyone has any feedback of the JES9860 as far as if they like it, hate it or otherwise, can you please post. I'm getting ready to make a huge committment. Thanks much and good luck.
Dec 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Kitchen Ranges Logo
114 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
